The update this weekend to solve my problem that the DVR is offline… didnt help. I tried to restart PMS but no luck… now I can se xteve in upnp app… but… still offline.
Yes, Plex only allows one EPG source.
Did you restart Plex?
Start xTeVe as a normal user directly from the command prompt. Then it stays open if an error occurs. I have to see what’s there, so I know what’s not working.
Yes I did.
Delete xTeVe from the Plex DVR settings, delete the settings.json from xTeVe, restart Plex and set up xTeVe manually via the IP address:port
v1.1.0 with xepg fricken rocks…
- my only issue is some episodes 1/10 approx fail to record… ie click record and they do not show up in future recordings nor do they record when time comes…
any ideas? is this epg error, plex error or xteve issue?
suggestion:
can xepg group same name episodes (give unique id?)and organize better as i have set as Shows category but they go to different folders and recording all shows of Title X not working great
Also would help record all episodes and prevent recording duplicates
i have qnap. use qnap forum version 1.0.2 then stop and restart
thanks man restart updated it all good
This is excellent work, thank you!
One change I would like to see is an option to specify where the xteve.xml file is saved to.
Thanks again!
Is there a way to install this headless on a VPS? Ubuntu?
My Plex server is cloud based and just wondered if there was a way to install it.
Thanks.
Jon.
For what reason do you want a different location? xteve.xml is a temporary file, so it will be saved in the tmp folder.
If you have access to your server with SSH, then you can also set up xTeVe there.
A description of how to run xTeVe on Linux, FreeBSD and OS X is available in the Discord channel #faq
I have a Plex installation in a docker image on a server at Bytesized. I can run the binary through SSH but have no access to /tmp
I’ve also installed this on a Synology NAS and that runs really well. Thanks again.
From xTeVe there is also a Docker Image. To be found in the Discord channel #faq
Is it possible to adjust the quality that we look in plex via a TV channel or in Xteve
Not sure what you mean…
Do you mean to adjust the quality of the actual stream playing - I think this is not possible
Or do you mean to get Plex to show that it is a HD or SD stream - this is possible… just add ‘HD’ to the end of the channel name in xTeVe mapping and Plex will show it as HD.
Adjust the quality view under plex. thank you for the little details
upcoming plex release has live tv reconnect, does this /can we apply to iptv?
I miss only to full happiness to different EPGs, after the name they mapped.
Can I buy you coffee?
