xTeVe - IPTV for Plex DVR
Can I sort the channel list in some easy way?
With my provider i can only have 1 tuner for 1 account, can I have many account and set many tuner ? (multiple session of xteve ?)
I am also experiencing this problem with,
2018-12-12 15:00:58 [xTeVe] [ERROR] XML syntax error on line 35: invalid character entity Ć© -
Line 1 reads,
<?xml version="1.0" encoding="UTF-8"?>
Line 35 reads,
<display-name>AMI-t&eacute;l&eacute;</display-name>
I can also open it in both Firefox and Chrome.
Your XML file is invalid, as &amp;eacute; isn't a default character entity for XML documents.
You should to replace it by &amp;#201; or to correctly encode it.
in HTML &amp;eacute; = Ɖ
in XML &amp;#201; = Ɖ
xTeVe uses the XML framework of Google, I trust the error messages.
Hey marmel,
Have you given any thought to throwing your project up on Github or something to that effect? Would love to help contribute to this project.
Take care,
I have used PMS as epg carrier. I tried xepg but my list loses their mappings all the time… I use the epg from my iptv source… but no luck… what do I do wrong?
How to install xteve in linux?
What commands should I use to download and install xteve?
Follow directions
How can I install xTeVe on a Raspberry Pi 1 running Raspbian GNU/Linux 9 (for Pi-hole).
Which installer do I need to download and how do I install it and run it through the command line?
Hello Can I try it out can you send it to my mail Joannaeski@gmail.com
Hi @marmei, decided to get back on this now that Plex made some changes to make the Live TV function better. Got it more or less setup but I have some questions:
  1. what’s the best way to get this running as a service on linux? I tried creating systemctl .service file and it fails to start… any advice?
error when I do a systemctl status xteve.service:
ExecStart=/usr/local/bin/xteve/xteve_local -port=ā€œ7070ā€ (code=exited, status=203/EXEC)
  1. has anyone figured out a good alternative logo/graphic/ source to Gracenote, I’m talking about full experience much in the way Gracenote provides (graphics for tvshows, movies, news channels, sports as well as logos for channel), but not fond of their limited EPG options.
  2. I’ve got a channel that errors out in plex, but works in other iptv clients (ex. GSE). Could I send you sample for troubleshooting?
Thanks for your hardwork! I stepped in to catchup on all the improvements being made and it’s great this is still thriving!
Welcome back.
  1. There is a Linux script (systemd) in the Discord channel. you do not have to specify the port, xTeVe remembers the port.
  2. I use Schedules Direct, but there are other providers as well. Do you also find in the Discord channel.
  3. Plex does not play every streaming format, unfortunately I can not change that. By now I use Emby
@marmei is there a way for xteve to auto map channels if using a third party epg like schedules direct?
No, the auto mapping only works if the tvg-id (M3U) matches the channel ID (XMLTV).
Thanks @marmei,
Ok, you’re making me curious about emby now… perhaps i’ll look into it.
Are you saying that Schedules Direct provides EPG but also with full show, tv and movie graphics in live tv like Gracenotes, (not just channel logos)?
I don’t seem to read much on their site about logos and graphics… it seems to be only EPG scheduling data which I think i’ve taken care of using WebGrab++
will check out discord soon…
They now also use GraceNote (if running beta) data and it’s similar to Plex in that it has logos, posters, actors. Basically everything you need. It’s much better than using Zap2XML or WebGrab++ (I was using them both). Nice clean and fast image servers. I wouldn’t consider Schedule Direct at this point as there is nothing to gain from it except extra $.
Hey thanks! I read Emby supports multiple EPGs too so this is the plus! Will report back on my findings as things progress.
Yes, that’s pretty good.
Costs $ 25 a year and you need another program, which creates an XMLTV file from the data of Schedueles Direct.
On my server, everything runs automatically every night and I always have the EPG data for the next 14 days.
xTeVe now also supports several XMLTV files.
Everything worked until now. The channels were copying themselves. Now it is not done. The worst thing is that when Xteve works well, after the XTEve refreshes the EPG stops working.
Can you look at my settings. PRV.
Are you totally at Emby?
