Make sure you restart xTeVe and Plex, then under xTeVe Settings set Stream Buffer to FFmpeg. I had the same issue last night and then when I changed the stream buffer everything worked. Hope this helps.
Iām trying to run xTeve on Mac and the terminal chucks out the following message. Canāt get any further.
[xTeVe] [ERROR] listen udp4 224.0.0.0:1900: bind: address already in use () - EC: 0
Any ideas?
I need the new program time shift functionality. Unfortunately, Webgrab gets data in this format:
"programme start=ā20191214230000 +0100"ā
Unfortunately, the offset is not recognized by Kodi or Plex.
The format is OK, only the stop time is missing.
If the time is correct on the Plex Server and the clients, the time offset is taken into account.
<programme channel="1" start="20191216012800 +0000" stop="20191216013000 +0000">
<title lang="de">Tagesschau</title>
<sub-title lang="de">vom 16.12.2019, 02:28 Uhr</sub-title>
<desc lang="de">
Diese Sendung berichtet über die aktuellsten und wichtigsten Nachrichten der Bundesrepublik. [vom 16.12.2019, 02:28 Uhr]
</desc>
<category lang="en">News</category>
<category lang="en">Politics</category>
<category lang="en">Weather</category>
<category lang="en">-</category>
<episode-num system="dd_progid">EP02828963.7429</episode-num>
<episode-num system="original-air-date">2019-12-16</episode-num>
<icon height="720" src="http://plex.local:34400/images/22b174a38932b7fc437d24efea1a8ede.jpg" width="480"/>
<icon height="540" src="http://plex.local:34400/images/193b67feb6f68597d89f14fcbe926eb1.jpg" width="960"/>
<video>
<quality>HDTV</quality>
</video>
<date/>
<new/>
<live/>
</programme>
Someone from WebGrab helped me a lot and now I have EPG in the Premium version.
Will you please tell me why some programs do not work on Plex Android application and work on another program? Itās probably the Plex playerās fault.
Do you have an idea how to install vlc on Qnapa (Linux)?
I canāt stream rtp-streams from Deutsche Telekomās MagentaTV anymore, which worked last week, when I started using xTeVe. I think that happens after upgrading xTeVe from 2.1.0 to 2.1.1 but not shure. Where can I download the old 2.1.0 to check? I hav not backup of the binary
Other streams (all http, no rtp) work fine.
plex (pass) version 1.18.3.2156 on debian buster amd64.
when I try to use the ffmpeg command directly on the console with option -report I get:
Command line:
ffmpeg -hide_banner -loglevel verbose -report -i rtp://87.141.215.251@232.0.20.35:10000 -c copy -f mpegts pipe:1
Opening an input file: rtp://87.141.215.251@232.0.20.35:10000.
[rtp @ 0x5633f21740c0] No default whitelist set
[udp @ 0x5633f21747c0] No default whitelist set
[udp @ 0x5633f21747c0] end receive buffer size reported is 131072
[udp @ 0x5633f2184ec0] No default whitelist set
[udp @ 0x5633f2184ec0] end receive buffer size reported is 131072
[EDIT forgot log from xTeVe:]
:00 [xTeVe] Streaming URL: rtp://87.141.215.251@232.0.20.35:10000
:00 [xTeVe] FFMPEG: Processing data
:00 [xTeVe] Streaming Status: Receive data from FFMPEG
:20 [xTeVe] Streaming Status: Client has terminated the connection
:20 [xTeVe] Streaming Status: Channel: Das Erste HD (Clients: 0)
Great work anyway. I love xTeVe with plex
Holger
OK, found the old xteve-2.1.0 on my system from my first testings. That was not the problem.
DAMN. Sorry! I thought I checked taht. But it seems that I even get no stream with vlc on Windows using the rtp-urls. Seems that either is problem with my provider (internet = TV) or my all new fritz!box router. ā¦investigating
Iām having a new issue with the Xbox One and XteVe with an endless buffer about 15minutes into the stream. Iām not usually using the Xbox as the LiveTV player, but it used to be fine a couple of months ago. All other devices are fine.
Iāve tried all the different buffer options and also xTeVe 2.1. Iām not entirely sure if itās an xTeVe issue or a Plex platform bug. Anyone else getting this problem?
I want to migrate my PMS server to another computer. Are there instructions on how to migrate my Xteve settings as well? I made a lot of channel restrictions and channel number remaps.
Iām trying to use this m3u which is made for kodi, other than 2-3 channels which redirect to kodi plugin all other links are streams.
when I play the channel I get āunable to play channel check antennaā
any idea what is wrong with this list?
For me at least, I had to delete the HDHR and add the xteve tuner then select the cable and channels which got the tuner with almost 400 channels showing up. Right now my problem seems to be channel mapping, looks like 90% of the channels are giving the same guide info⦠
Thanks. Yes, thatās a bug. Will be fixed in the next update.
Good Afternoon All,
I have been using Xteve with Plex for the last few months on a variety of PCs and devices and several different IPTV providers and have been very impressed with Xteve so far.
However, in the last few weeks I have been getting the following error when changing channels:
āPlayback has stopped because the connection to the Plex Media Server has been lostā
I have tried using different stream buffers on Xteve and different IPTV providers aswell and even different versions of Xteve - but unfortunately nothing works and I was wondering if anyone else had encountered similar issues?
Cheers
Steve
xTeVe 2.1.1 tries to set a user-agent for ffmpeg. Unfortunately ffmpeg does not have a parameter to do this. So 2.1.1 does not work with ffmpeg because of an error. Maybe this only happens if one set the user-agent option in xteve settings.
Hi!One question!
Do I really need the DVR to watch the channels, when I use the xTeve?
My problem is, that my Plex (xTeve) see all my channels, but doesnāt
reproduce them or record.Gives me error.Thatās becouse I donāt have a DVR?
Where do the channels come from?
Like a link from my IPTV provider or list from somewhere
And it completely works when I check it in vlc player.
Does anybody here use (watch and record) xTeve without DVR?
Is it possible?
