xTeVe - IPTV for Plex DVR
This is because your “normal” user does not have permission to write the xteve.exe file. I’m not so familiar with Windows, but that can certainly be set for the “normal” user.
In which folder is xteve.exe?
Yeah, I already knew that and have given my user full control now anyway… I was more posting in case anyone else ran into the same error and didn’t know what to do
Are you still offering beta keys for this? I’ve been looking for something exactly like this for so long. Please let me know if you can provide me with a download and key,
Thank you.
The download link is at the top, the key I send via PM
This looks incredible! How might I obtain a beta key? I’ve successfully used tvhProxy, but it had it’s problems. I am so excited about this!
updated to 0.1.46 but cant see any changelog since 0.1.40? what has changed?
also xteve.de is giving a 404 error
small bugs have been fixed and a few things have changed on the Web UI.
the link has never worked,
http://beta.xteve.de is the right one
@marmei is xTeVe something that I can use on my Nvdia Shield? If so, I’d be interested in beta testing it.
Thanks in advance.
There are ARM binaries from xTeve, but I do not know if you can do them on the Nvidia Shield.
Yes, that’s why I asked. Usually I install *.apk apps/files, so I’m not even sure how I would go about to test this…
Anyone have any idea how this can be installed on Nvidia Shield?
Hello,
I’m running xteve and added my m3u list. The list is imported and xteve is shown as sillicondust tuner in my plex server. But it appeared only a very short moment than it was gone.
What should I do?
web service of xteve is still running fine and shows 166 channels
Best regards,
Stefan
It did that to me… It still seems to work if you enter the ip address of xTeVe - click ‘connect’ and then click continue straight away
No I, get following error message:
Ein Fehler ist aufgetreten beim Hinzufügen von Gerät: 192.168.88:10:34400
Then you have a network problem, firewall for example
Ok, can I use the beta key on a different Computer or Installation?
No, that’s not possible, the key is only for one computer.
Can you please delete the old one and sent me a new one?
I’m running a vdr Server with Streamdev plugin. This plugin provides a m3u playlist which I would like to add to plex.
The first Installation of xteve was on my plex Server. Now I wohl ld like to try it on my vdr server
If xTeVe is installed on the same server as Plex, then you can also enter 127.0.0.1:34400 as the address in Plex.
I tried 127.0.0.1:34400 and was able to connect to a silicon dust tuner xteve but no channels showed up.
I tried a second time but this time I dont get any connection to xteve
Did you ever restart the Plex server? How many streams does xTeVe show as available?
Please send me a screenshot of the console. PM
