xTeVe - IPTV for Plex DVR
In the settings you enter the sum of all tuners per playlist.
Example:
Playlist 1 = 2 tuners
Playlist 2 = 4 tuners
xTeVe Tuner Settings = 6
When a playlist reaches this limit, an error message is sent to Plex as a video stream.
Does any of you have the problem that when you turn on the TV, then after turning off the Plex channel, it goes into an intermediate state, instead of a direct one?
After rebooting, Plex is fine until I turn on the TV again.
\\EDIT:
I have analyzed the matter. It turned out that in the new place everything started working after turning on uPnP.
I have comstar iptv and since they only allow 1 stream to each active account, they sold me a second account with a new m3u and xmltv URL. It has a new username/password for this new account. I’m running into an issue where if I add the new account m3u to the m3u page, I get more than the 480 limit and the mappings are all pointing to the original stream. Is there a way for a channel to be mapped to 2 channels? If this isn’t possible, can I install a second docker with a different IP so I can have it show up as a second tuner for Plex? Thanks in advance.
Hi, I am trying to combine the Octopus-Net with xTeVe and Plex. In former time I used Mosaic TV to connect to the octopus net, than xTeVe used Mosaic TV as source and finally I confugured the xTeVe Tuner in plex. This combination worked.
However, TV Mosaic is no longer continued and I switched my NAS from QNAP to FreeNAS. Therefore I have the following combination now: xTeVe (installed as jail with a separate IP-address) uses the m3u file from Octopus net and in Plex (also installed as jail with an own IP-address) I configured the xTeVe Tuner.
Now if I try to watch live tv, I get the message in plex I should check the antenna, and the following error logs are displayed:
Nov 17, 2020 17:04:35.481 [0x80c1ccb00] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:04:35.481 [0x8133a3a00] Fehlersuche β€” Request: [10.40.1.5:49954 (WAN)] POST /livetv/dvrs/13/channels/117/tune (6 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:04:35.481 [0x8133a3a00] Fehlersuche β€” Subscription: Starting a new rolling subscription for session natonu4uufj5vuxjv5pacipv channel 117.
Nov 17, 2020 17:04:35.493 [0x8133a3a00] Fehlersuche β€” Activity: registered new activity 116e9457-ae43-455d-9262-98c4a500f9d2 - Refreshing Sub
Nov 17, 2020 17:04:35.493 [0x8133a3a00] Fehlersuche β€” Activity: updated activity 116e9457-ae43-455d-9262-98c4a500f9d2 - completed 0.0% - Refreshing Sub
Nov 17, 2020 17:04:35.493 [0x8133a3a00] Fehlersuche β€” Activity: registered new activity e5b77f6a-b037-4021-890f-9556adde9de5 - Processing subscriptions
Nov 17, 2020 17:04:35.493 [0x8133a3a00] Fehlersuche β€” Subscription: Scheduling subscriptions.
Nov 17, 2020 17:04:35.494 [0x8133a3a00] Fehlersuche β€” Subscription: Initialized 1 schedulers.
Nov 17, 2020 17:04:35.494 [0x8133a3a00] Fehlersuche β€” Subscription: Starting with 0 grabs, scheduled 0 active ones preemptively.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Subscription: Failed to resolve subscription for episode 'grandparentGuid: plex://show/5eef0aaea6175a0042b87f3f grandparentThumb: http://cps-static.rovicorp.com/2/Open/MediaPress_4498/Program/40708595/11b4cca372c440b9e9085637fcf0f0827aff656f.jpg grandparentTitle: Formel 1: Großer Preis von Belgien grandparentYear: 2020 guid: plex://episode/5f3d1b0879a2c20041774e2d originallyAvailableAt: 2020-08-30 parentGuid: plex://season/5eef0aaea6175a0042b87f3f/2020 parentIndex: 2020 parentTitle: Staffel 2020 ratingKey: plex%3A%2F%2Fepisode%2F5f3d1b0879a2c20041774e2d tagline: Diese Sendung title: Das Rennen type: 4 year: 2020' to library item
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Partitioning, step one, let's compute an absolute ordering.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€”  DVR:NewSchedule: Between 2020-11-17 17:04:35 and 2020-11-17 17:09:35 on channel 117: 'Live TV - Session'
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Initial partitioning completed with 1 partitions.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Partitioning completed with 1 partitions.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: PARTITION of size 1.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: After processing the partition, we have 2 alternate realities.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: We computed 2 alternative realities in 0 ms.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: The winning schedule had score: 10 and 0 conflicts.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€”  DVR:NewSchedule: device 0 tuner 1 airing 0 between 2020-11-17 17:04:35 and 2020-11-17 17:09:35 on channel 117: 'Live TV - Session'
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Grabber: Starting grab immediately for 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117 and we're 0 seconds in already.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Subscription: Scheduled all subscriptions in 1 ms.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Activity: Ended activity e5b77f6a-b037-4021-890f-9556adde9de5.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Subscription: There are 1 active grabs at the end.
Nov 17, 2020 17:04:35.495 [0x8133a3a00] Fehlersuche β€” Subscription: Waiting for media grab to start.
Nov 17, 2020 17:04:35.495 [0x80c5ea200] Fehlersuche β€” Grabber: Starting operation for 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117.
Nov 17, 2020 17:04:35.495 [0x80c5ea200] Fehlersuche β€” Activity: registered new activity 1ff56f44-0fd7-4535-890b-f9a44ff3aa8d - Recording
Nov 17, 2020 17:04:35.495 [0x80c5ea200] Fehlersuche β€” Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/2020-11-16WF-TQ6WWP:2 (Silicondust xTeVe, supported) tuner 1.
Nov 17, 2020 17:04:35.495 [0x80c5ea200] Fehlersuche β€” Grabber: Creating custom segmented recorder for grab for channel 117
Nov 17, 2020 17:04:35.495 [0x80c5ea200] Fehlersuche β€” HTTP requesting GET http://192.168.1.93:34400/lineup.json
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” HTTP 200 response from GET http://192.168.1.93:34400/lineup.json
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” DVR:Segmenter: Creating a new recorder for http://192.168.1.93:34400/stream/1c185d92e819b8006c81b2912bc5a221.
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Grabber: Setting timer to stop grab of 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117 in 300 seconds.
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Grabber: Waiting for a tuner on device://tv.plex.grabbers.hdhomerun/2020-11-16WF-TQ6WWP:2 (2 available) for at most 300 seconds.
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Grabber: Allocated a tuner on device://tv.plex.grabbers.hdhomerun/2020-11-16WF-TQ6WWP:2 (1 left)
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” We're going to try to auto-select an audio stream for account 1.
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Selecting best audio stream for part ID -1 (autoselect: 1 language: de)
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” We're going to try to auto-select a subtitle.
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Selected a foreign audio track:
Nov 17, 2020 17:04:35.496 [0x80c5ea200] Fehlersuche β€” Audio Stream: -1, Subtitle Stream: -1
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: Selected protocol hls; container: mpegts
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehler β€” Unable to find title for item of type 5
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: analyzing media item -1
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: : no direct play video profile exists for http/mpegts/
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: : no direct play video profile exists for http/mpegts//
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: : codec is unavailable for analysis
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” MDE: : selected media 0 / -1
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” Cleaning directory for session e1e97a1d-acab-46cd-8310-aaa7b1457c60 ()
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” Starting a transcode session e1e97a1d-acab-46cd-8310-aaa7b1457c60 at offset -1.0 (state=3)
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” Streaming Resource: Added session 0x8138f5298:e1e97a1d-acab-46cd-8310-aaa7b1457c60
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” Job running: EAE_ROOT='/tmp/pms-35a787be-4372-4b1e-925e-eb01f5d1e8e7/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/Plex\ Media\ Server/Codecs/5f603a2-3204-freebsd-x86_64/' XDG_CACHE_HOME='/Plex Media Server/Cache' XDG_DATA_HOME='/usr/local/share/plexmediaserver/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/local/share/plexmediaserver/Plex Transcoder' '-noaccurate_seek' '-ignore_unknown' '-scan_all_pmts' '-1' '-rw_timeout' '30000000' '-reconnect' '1' '-reconnect_streamed' '1' '-reconnect_delay_max' '30' '-fflags' '+discardcorruptts+fillwallclockdts' '-probesize' '20000000' '-i' 'http://192.168.1.93:34400/stream/1c185d92e819b8006c81b2912bc5a221' '-map' '0:V?' '-codec:V' 'copy' '-map' '0:a?' '-codec:a' 'copy' '-map' '0:s?' '-codec:s' 'copy' '-break_non_keyframes' '1' '-segment_format' 'mpegts' '-f' 'ssegment' '-individual_header_trailer' '0' '-segment_time' '1' '-segment_start_number' '0' '-segment_time_delta' '0.25' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/seglist?X-Plex-Http-Pipeline=infinite' '-segment_list_type' 'csv' '-segment_list_size' '5' '-segment_list_separate_stream_times' '1' '-segment_list_unfinished' '1' '-max_delay' '5000000' '-map_metadata' '-1' '-map_chapters' '-1' 'media-%05d.ts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-xioerror' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress'
Nov 17, 2020 17:04:35.497 [0x80c5ea200] Fehlersuche β€” Jobs: Starting child process with pid 15407
Nov 17, 2020 17:04:35.498 [0x81505d000] Fehlersuche β€” HTTP requesting GET http://192.168.1.93:34400/discover.json
Nov 17, 2020 17:04:35.498 [0x81505d000] Fehlersuche β€” HTTP 200 response from GET http://192.168.1.93:34400/discover.json
Nov 17, 2020 17:04:35.498 [0x81505d000] Fehlersuche β€” HTTP requesting GET http://192.168.1.93:34400/lineup_status.json
Nov 17, 2020 17:04:35.498 [0x81505d000] Fehlersuche β€” HTTP 200 response from GET http://192.168.1.93:34400/lineup_status.json
Nov 17, 2020 17:04:35.499 [0x814f76600] Fehlersuche β€” Request: [127.0.0.1:51605 (Loopback)] PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=startup (7 live) Signed-in Token (florian.rhomberg) (range: bytes=0-)
Nov 17, 2020 17:04:35.499 [0x80c1cc600] Fehlersuche β€” Completed: [127.0.0.1:51605] 204 PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=startup (7 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Nov 17, 2020 17:04:35.506 [0x814f76600] Fehlersuche β€” Request: [127.0.0.1:51605 (Loopback)] PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=startup (7 live) Signed-in Token (florian.rhomberg) (range: bytes=0-)
Nov 17, 2020 17:04:35.506 [0x80c1ccb00] Fehlersuche β€” Completed: [127.0.0.1:51605] 204 PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=startup (7 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Nov 17, 2020 17:04:35.506 [0x814f76600] Fehlersuche β€” Request: [127.0.0.1:51605 (Loopback)] PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=opening (7 live) Signed-in Token (florian.rhomberg) (range: bytes=0-)
Nov 17, 2020 17:04:35.506 [0x80c1ccb00] Fehlersuche β€” Completed: [127.0.0.1:51605] 204 PUT /video/:/transcode/session/e1e97a1d-acab-46cd-8310-aaa7b1457c60/072f03eb-32dd-4768-a518-bc93e8f7399d/progress?status=opening (7 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Nov 17, 2020 17:04:35.517 [0x814f76600] Fehler β€” [Transcoder] http://192.168.1.93:34400/stream/1c185d92e819b8006c81b2912bc5a221: Invalid data found when processing input
Nov 17, 2020 17:04:35.518 [0x80b8bd800] Fehlersuche β€” Jobs: '/usr/local/share/plexmediaserver/Plex Transcoder' exit code for process 15407 is 1 (failure)
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” TranscodeSession: session failed while waiting for duration
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehler β€” Failed to start session.
Nov 17, 2020 17:04:35.518 [0x80c1cc100] Fehlersuche β€” Streaming Resource: Terminated session 0x8138f5298:e1e97a1d-acab-46cd-8310-aaa7b1457c60 with reason Recording failed. Please check your tuner or antenna.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehler β€” Recorder: Unable to create transcode session or session failed to start.
Nov 17, 2020 17:04:35.518 [0x8138e9900] Fehlersuche β€” Killing job.
Nov 17, 2020 17:04:35.518 [0x8138e9900] Fehlersuche β€” Signalling job ID 15407 with 9
Nov 17, 2020 17:04:35.518 [0x8138e9900] Fehlersuche β€” Job was already killed, not killing again.
Nov 17, 2020 17:04:35.518 [0x8138e9900] Fehlersuche β€” Stopping transcode session e1e97a1d-acab-46cd-8310-aaa7b1457c60
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Job was already killed, not killing again.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehler β€” Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Grabber: Cleaning up rolling grab for channel 117.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Recorder: No more consumers, stopping.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Recorder: Asked to stop recording 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Grabber: Freed a tuner on device://tv.plex.grabbers.hdhomerun/2020-11-16WF-TQ6WWP:2 (now 2 available)
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Grabber: Operation for 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117 completed with status error (Recording failed. Please check your tuner or antenna.)
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Activity: Ended activity 1ff56f44-0fd7-4535-890b-f9a44ff3aa8d.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Activity: updated activity 116e9457-ae43-455d-9262-98c4a500f9d2 - completed 100.0% - Refreshing Sub
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Activity: Ended activity 116e9457-ae43-455d-9262-98c4a500f9d2.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehler β€” Grabber: Starting media grab failed.
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehler β€” Unknown metadata type:
Nov 17, 2020 17:04:35.518 [0x80c5ea200] Fehlersuche β€” Asked for unknown type: -1
Nov 17, 2020 17:04:35.518 [0x8133a3500] Fehlersuche β€” Cleaning directory for session e1e97a1d-acab-46cd-8310-aaa7b1457c60 (/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-e1e97a1d-acab-46cd-8310-aaa7b1457c60)
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehler β€” Subscription: Rolling media grab failed to start.
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehlersuche β€” Subscription: Cancelling grab for subscription 33: 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehlersuche β€” Grabber: Cancelling operation for 'Live TV - Session natonu4uufj5vuxjv5pacipv' on channel 117 with status cancelled.
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehlersuche β€” Grabber: Operation was active, stopping recorder.
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehlersuche β€” Grabber: We've cancelled the grab with 300 seconds remaining.
Nov 17, 2020 17:04:35.518 [0x8138e9900] Fehlersuche β€” Transcoder: Cleaning old transcode directories.
Nov 17, 2020 17:04:35.518 [0x8133a3a00] Fehlersuche β€” Activity: registered new activity cce67f57-01ed-40f8-8c72-494f2bba2ba8 - Processing subscriptions
Nov 17, 2020 17:04:35.519 [0x8133a3a00] Fehlersuche β€” Subscription: Scheduling subscriptions.
Nov 17, 2020 17:04:35.519 [0x8138e9900] Fehlersuche β€” Whacked session e1e97a1d-acab-46cd-8310-aaa7b1457c60, 0 remaining.
Nov 17, 2020 17:04:35.519 [0x8133a3a00] Fehlersuche β€” Subscription: Initialized 1 schedulers.
Nov 17, 2020 17:04:35.519 [0x8133a3a00] Fehlersuche β€” Subscription: Starting with 0 grabs, scheduled 0 active ones preemptively.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” Subscription: Failed to resolve subscription for episode 'grandparentGuid: plex://show/5eef0aaea6175a0042b87f3f grandparentThumb: http://cps-static.rovicorp.com/2/Open/MediaPress_4498/Program/40708595/11b4cca372c440b9e9085637fcf0f0827aff656f.jpg grandparentTitle: Formel 1: Großer Preis von Belgien grandparentYear: 2020 guid: plex://episode/5f3d1b0879a2c20041774e2d originallyAvailableAt: 2020-08-30 parentGuid: plex://season/5eef0aaea6175a0042b87f3f/2020 parentIndex: 2020 parentTitle: Staffel 2020 ratingKey: plex%3A%2F%2Fepisode%2F5f3d1b0879a2c20041774e2d tagline: Diese Sendung title: Das Rennen type: 4 year: 2020' to library item
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Partitioning, step one, let's compute an absolute ordering.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Initial partitioning completed with 0 partitions.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: Partitioning completed with 0 partitions.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: We computed 1 alternative realities in 0 ms.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” DVR:NewSchedule: The winning schedule had score: 0 and 0 conflicts.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” Subscription: Scheduled all subscriptions in 1 ms.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” Activity: Ended activity cce67f57-01ed-40f8-8c72-494f2bba2ba8.
Nov 17, 2020 17:04:35.520 [0x8133a3a00] Fehlersuche β€” Subscription: There are 0 active grabs at the end.
Nov 17, 2020 17:04:35.520 [0x80c1ccb00] Fehlersuche β€” Completed: [10.40.1.5:49954] 200 POST /livetv/dvrs/13/channels/117/tune (6 live) TLS GZIP 38ms 563 bytes (pipelined: 1)
Nov 17, 2020 17:04:35.976 [0x80c1ccb00] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:04:35.976 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49954 (WAN)] GET /tv.plex.providers.epg.cloud:13/grid?type=1%2C4&sort=beginsAt&endsAt%3E=1605628800&beginsAt%3C=1605634200 (6 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:04:35.986 [0x80c1cc600] Fehlersuche β€” Completed: [10.40.1.5:49954] 200 GET /tv.plex.providers.epg.cloud:13/grid?type=1%2C4&sort=beginsAt&endsAt%3E=1605628800&beginsAt%3C=1605634200 (6 live) TLS GZIP 10ms 16951 bytes (pipelined: 2)
Nov 17, 2020 17:04:36.325 [0x80c1cc600] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:04:36.325 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49955 (WAN)] GET /tv.plex.providers.epg.cloud:13/tags?type=310 (7 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:04:36.326 [0x80c1cc600] Fehlersuche β€” Completed: [10.40.1.5:49955] 200 GET /tv.plex.providers.epg.cloud:13/tags?type=310 (7 live) TLS GZIP 0ms 1323 bytes (pipelined: 1)
Nov 17, 2020 17:04:36.500 [0x8138b7800] Fehlersuche β€” DVR:Segmenter: Stopping idle session: http://192.168.1.93:34400/stream/1c185d92e819b8006c81b2912bc5a221.
Nov 17, 2020 17:04:38.986 [0x80c1cc600] Fehlersuche β€” Completed: [10.40.1.5:49934] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (7 live) TLS GZIP 20055ms 5 bytes (pipelined: 1)
Nov 17, 2020 17:04:39.123 [0x80c1ccb00] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:04:39.123 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49954 (WAN)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (6 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:04:39.123 [0x814f76600] Fehlersuche β€” Content-Length is -1 (of total: -1).
Nov 17, 2020 17:04:59.126 [0x80c1ccb00] Fehlersuche β€” Completed: [10.40.1.5:49954] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP 20002ms 5 bytes (pipelined: 3)
Nov 17, 2020 17:04:59.760 [0x80c1cc600] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:04:59.760 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49975 (WAN)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:04:59.760 [0x814f76600] Fehlersuche β€” Content-Length is -1 (of total: -1).
Nov 17, 2020 17:05:01.062 [0x80c5eb600] Fehlersuche β€” EPG[cloud]: Next thing to start/end is at 2020-11-17 16:10:00 GMT (in 300 seconds)
Nov 17, 2020 17:05:01.439 [0x80c1cc600] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:05:01.439 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49976 (WAN)] GET /tv.plex.providers.epg.cloud:13/grid?type=1%2C4&sort=beginsAt&endsAt%3E=1605628800&beginsAt%3C=1605634200 (7 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:05:01.449 [0x80c1ccb00] Fehlersuche β€” Completed: [10.40.1.5:49976] 200 GET /tv.plex.providers.epg.cloud:13/grid?type=1%2C4&sort=beginsAt&endsAt%3E=1605628800&beginsAt%3C=1605634200 (7 live) TLS GZIP 10ms 16962 bytes (pipelined: 1)
Nov 17, 2020 17:05:01.478 [0x80c1ccb00] Fehlersuche β€” Auth: authenticated user 1 as florian.rhomberg
Nov 17, 2020 17:05:01.478 [0x814f76600] Fehlersuche β€” Request: [10.40.1.5:49977 (WAN)] GET /tv.plex.providers.epg.cloud:13/tags?type=310 (7 live) TLS GZIP Signed-in Token (florian.rhomberg)
Nov 17, 2020 17:05:01.479 [0x80c1cc600] Fehlersuche β€” Completed: [10.40.1.5:49977] 200 GET /tv.plex.providers.epg.cloud:13/tags?type=310 (7 live) TLS GZIP 0ms 1323 bytes (pipelined: 1)
Nov 17, 2020 17:05:17.734 [0x8133a3500] Fehlersuche β€” Analyzing media parts for item 130777 (004): 123125
There seems to be a problem with the decoder or the not existing subtitle? Is this right and if so how can I solve this?
Hope someone can help me!
Thanks to the developer of xTeVe!
Florian
Having an issue with Xteve and Plex, with Plex saying β€œcould not tune channel. Please check tuner or antenna.”
The issue is not with Xteve or the m3u playlist as the xteve m3u streams perfectly fine in VLC.
The m3u has no limits on streams either.
PMS v 1.20.5.3600 running on Windows 10, Xteve running through Docker. Very frustrating that there seems to be no fix for this.
Running xteve 2.1.2 on docker (unraid)
The stream is m3u8 streams of my local enigma2 Linux cable box.
If I start a stream in Plex, live Tv always occupies all 4 tuner which I allow for xteve. If a recording is running, a fifth Stream is opened. Why the heck is Plex grabbing the same stream from 4 different tuners?
Ditto, same problem, works fine in emby the streams work fine but plex instantly reports the error you described
I too am experiencing the looping issue with the current release of xteve and Plex.
I’ve seen a bunch of posts from others that seem to be experiencing the same thing, but can’t find any post that document the root cause or any resolutions or work arounds.
Is there any resolution to the looping issue?
The looping issue can be replicated via a TV tuner, xTeVe and dizqueTV. There is something going on with how PLEX is managing this type of content.
It would be great to have a m3u tunner native to PLEXl to separate out the EPG dependency. Worse case, I’ve been using VLC to watch the streams, but would love to have access to this content within PLEX and available outside my network.
I have the same probleme! Sometimes ist works for hours and sometimes ist starts after some minutes! Pls Help i have no idea how to solve it
I have an issue with xTeve replacing the show icons with wrong icons which are actually channel logos for a channel (the same channel the show is on i.e ABC or a different channel like CityTV in the example below)
Input file
        <programme start="20201223110000 -0800" stop="20201223120000 -0800" channel="I805.11766.tvguide.com">
                <title lang="en">General Hospital</title>
                <sub-title lang="en">12-23-2020</sub-title>
                <desc lang="en">Carly hides her concern. Michael takes Lucas by surprise. Molly and TJ spend Christmas Eve at Jordan and Curtis&apos;. Portia gives Curtis advice. Sasha $
                <date>2020</date>
                <category lang="en">Series</category>
                <icon src="https://tvguide1.cbsistatic.com/feed/1/774/thumbs/115765774_430x573.jpg" />
                <url>https://www.tvguide.com/tvshows/general-hospital/episode-66-season-58/12-23-2020/195503</url>
                <episode-num system="common">S58E66</episode-num>
                <episode-num system="xmltv_ns">57.65.</episode-num>
                <new />
                <rating>
                        <value>TV-14</value>
                </rating>
        </programme>
xTeve output XML file:
<programme channel="1079" start="20201223130000 -0800" stop="20201223140000 -0800">
          <desc lang="en">Carly hides her concern. Michael takes Lucas by surprise. Molly and TJ spend Christmas Eve at Jordan and Curtis&#39;. Portia gives Curtis advice. Sasha berates Brando.</desc>
          <icon height="" src="https://edgecdn.io:8443/img/city.png" width=""></icon>
          <video></video>
          <date>20201223</date>
          <new></new>
      </programme>
This does not happen for all channels, some channels do have the correct show logos.
Any ideas?
EDIT: Using the β€œDownload Enhanced Guide Data” in Plex solved this for me, Plex just downloaded the correct poster images
Has anyone used M3U4U with Plex having multiple tuners? My provider gives me access to one M3U/(EPG)XTML link that allows 5 connections. however because their images are all broken if I setup M3U4U I am only able to stream 1 connection at a time from their site. :frowning:
So I am not sure what the best plan is. Do I have to add the M3U/(EPG)XTML link 4 more times to M3U4U and (sigh) updates all the images for each then setup the tuners on each link to 1 on XTEVE?
Custom IPTV seems to be a very popular topic, so much that 3rd party apps are being developed to get around the Plex limitation.
Has Plex officially responded on adding this feature because from their end it would be as simple as their existing Live TV on Plex feature + add m3u list menu on the Plex server end - not difficult so I’m starting to think there is another reason this hasn’t happened :wink:
I just deleted my existing xteve tuner from Plex because I received an email from Plex to delete my existing tuner and re-add it again for an upcoming EPG provider change on Jan 15th.
Well… I just deleted my xteve tuner… but, can’t add it back. Plex detects it as a valid HDHR tuner… however, when I try to add it, I immediately see the the screen below. How do I fix this issue?
Screenshot_01-09-2021_05.57.12PM_
looking for some ideas. perhaps someone else has tried using Pluto for Channels DVR ( Pluto for Channels - Custom Channels - Channels Community ) which builds a playlist and EPG on a service for Pluto TV.
I’ve added both the playlist and epg to xTeVe as I would for any IPTV provider. All seems fine except none of the channels map to theXMLTV file or XMLTV ID. When I use the Mapping utility (Bulk) and point to the correct EPG the XMLTV ID is still blank. I can manually adjust them one by one.
looking at the logs it appears to try and map them but no joy.
2021-01-17 23:02:33 [xTeVe] Download: http://192.168.86.214/epg.xml
2021-01-17 23:02:33 [xTeVe] Check File: http://192.168.86.214/epg.xml
2021-01-17 23:02:34 [xTeVe] Save File: http://192.168.86.214/epg.xml [ID: XQZ2FRMZ54VLJ4DUEEF7]
2021-01-17 23:02:34 [xTeVe] All streams: 283
2021-01-17 23:02:34 [xTeVe] Active streams: 283
2021-01-17 23:02:34 [xTeVe] Filter: 0
2021-01-17 23:02:34 [xTeVe] XEPG: Parse XMLTV file: Pluto
2021-01-17 23:02:34 [xTeVe] XEPG: Update database
2021-01-17 23:02:39 [xTeVe] XEPG: Map channels
2021-01-17 23:02:39 [xTeVe] XEPG: Cleanup database
2021-01-17 23:02:40 [xTeVe] XEPG Channels: 0
2021-01-17 23:02:40 [xTeVe] [WARNING] There are no channels mapped, use the mapping menu to assign EPG data to the channels.
2021-01-17 23:02:40 [xTeVe] XEPG: Create XMLTV file (/home/xteve/.xteve/data/xteve.xml)
2021-01-17 23:02:40 [xTeVe] XEPG: Compress XMLTV file (/home/xteve/.xteve/data/xteve.xml.gz)
2021-01-17 23:02:40 [xTeVe] XEPG: Create M3U file (/home/xteve/.xteve/data/xteve.m3u)
2021-01-17 23:02:40 [xTeVe] XEPG: Ready to use
I assume I am doing something wrong so any suggestions would be appreciated.
BTW, I did point Channels DVR at xTeVe and it works. While Channels DVR has some very interesting features it has a lot of issues with correctly identifying content. The main item of interest is the shear number of sources that can be mapped including Cable streaming services.
thanks in advance
Ron
Pluto will not work since ffmpeg does not support EXT-X-DISCONTINUITY. You will get freezing or loops when a commercial starts or ends. Stirr works but has older stuff.
If you still want to try it here are the links you need:
Pluto:
Playlist: https://techzyon.com/epg/plutotv.m3u
Add EPG: https://techzyon.com/epg/plutotv_guide.xml
Stirr:
Add Playlist: https://techzyon.com/epg/stirr.m3u
Add EPG: https://techzyon.com/epg/stirr_guide.xml
Thanks for the quick reply and alternative links.
As a noob I don’t quite understand since it works fine including recording in Channels DVR. I like what they’ve done with the app but it is just sloppy where identifying content goes so a lot of maintenance is required.
Is this a CODEC limitation of Plex?
Not sure what you are referring to as limitation. The issue is that Pluto stops and starts the main video timestamps so it is not continues which causes everything to go out of sync. The transcoders need to be able to handle this which Plex, FFMpge and VLC does not. They need to be able EXT-X-DISCONTINUITY flag. Supposedly you can enabled this in FFMpeg but needs to be complied that way but I have not gone down that route to see if that would work.
You may have to delete it from the DB.
Hi, newbie here. Just followed the installation, applied filter to have less channels in the list. But, what should I do next? I can see the web adress in the browser, some infos about the streams, on the left, I have playlist, filter, XMLTV, Mapping, Settings, Log. I guess I’m missing something here. Can someone supply more infos about what to do when configuration is done. How do I access that in Plex? Setting up DVR cause I need to record some channels?
