Xteve & Movies
Hi everyone,
I am testing Xteve with my provider of IPTV. It is working good for all channels. My provider of IPTV have some channel with documentary or movies so there is no guide or program and it is not available. Have you got a solution ?
Your xTeVe config looks correct with the xTeVe Dummy as it will generate generic guide data. In Plex, if you are using the xTeVe EPG, you should have something like “1001 Channel Name” for the EPG mapping. In the guide, it will have 2 hours blocks that say something like “Channel Name (Th. 08:00-10:00).”
