This appears to be the same errors as was seen here, though that topic received no responses. I’ve attached the errors that were generated around the time of a failed tagging event - it looks like the queries being generated are being rejected by SQLite for some reason?
I’m hoping that someone has an idea what to do about this?
Server Version#:1.15.0.659
Logs:
Feb 15, 2019 17:04:30.996 [0x7f8b8b447700] Error — QueryParser: Invalid field 'onlyTransient' found, ignoring.
Feb 15, 2019 17:04:31.029 [0x7f8b8b447700] Error — QueryParser: Invalid field 'onlyTransient' found, ignoring.
Feb 15, 2019 17:04:32.607 [0x7f8b899e9700] Error — LPE: unknown item 65264.
Feb 15, 2019 17:04:32.607 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F65264%2Fchildren in sync item 21734878
Feb 15, 2019 17:04:32.608 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734878: unable to generate sync set query
Feb 15, 2019 17:04:32.609 [0x7f8b899e9700] Error — LPE: unknown item 75283.
Feb 15, 2019 17:04:32.609 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F75283%2Fchildren in sync item 21734882
Feb 15, 2019 17:04:32.609 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734882: unable to generate sync set query
Feb 15, 2019 17:04:32.611 [0x7f8b899e9700] Error — LPE: unknown item 79107.
Feb 15, 2019 17:04:32.611 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F79107%2Fchildren in sync item 21734888
Feb 15, 2019 17:04:32.611 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734888: unable to generate sync set query
Feb 15, 2019 17:04:32.613 [0x7f8b899e9700] Error — LPE: unknown item 78820.
Feb 15, 2019 17:04:32.613 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F78820%2Fchildren in sync item 21734895
Feb 15, 2019 17:04:32.613 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734895: unable to generate sync set query
Feb 15, 2019 17:04:32.616 [0x7f8b899e9700] Error — LPE: unknown item 72759.
Feb 15, 2019 17:04:32.616 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72759%2Fchildren in sync item 21734897
Feb 15, 2019 17:04:32.616 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734897: unable to generate sync set query
Feb 15, 2019 17:04:32.618 [0x7f8b899e9700] Error — LPE: unknown item 72747.
Feb 15, 2019 17:04:32.618 [0x7f8b899e9700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72747%2Fchildren in sync item 21734898
Feb 15, 2019 17:04:32.618 [0x7f8b899e9700] Error — Sync: skipping items for sync list 13113028, sync item 21734898: unable to generate sync set query
Feb 15, 2019 17:04:33.145 [0x7f8baba2d700] Error — SQLITE3:(nil), 1, statement aborts at 168: [update metadata_items set extra_data=? where metadata_type=? and library_section_id=? and `index`=?] SQL logic error
Feb 15, 2019 17:04:33.145 [0x7f8baba2d700] Error — Exception inside transaction (inside=1) (../Library/MetadataCollection.cpp:236): sqlite3_statement_backend::loadOne: SQL logic error
Feb 15, 2019 17:04:33.145 [0x7f8baba2d700] Error — JobManager: Caught an exception notifying process 22165: sqlite3_statement_backend::loadOne: SQL logic error
Feb 15, 2019 17:04:33.173 [0x7f8b8940d700] Error — downloadContainer: expected MediaContainer element, found html
Feb 15, 2019 17:04:33.176 [0x7f8b2b159700] Error — downloadContainer: expected MediaContainer element, found html
Feb 15, 2019 17:04:33.182 [0x7f8b896fb700] Error — downloadContainer: expected MediaContainer element, found html
Feb 15, 2019 17:04:33.184 [0x7f8b2a88f700] Error — downloadContainer: expected MediaContainer element, found html
Feb 15, 2019 17:05:01.714 [0x7f8b89cd7700] Error — LPE: unknown item 65264.
Feb 15, 2019 17:05:01.714 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F65264%2Fchildren in sync item 21734878
Feb 15, 2019 17:05:01.714 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734878: unable to generate sync set query
Feb 15, 2019 17:05:01.715 [0x7f8b89cd7700] Error — LPE: unknown item 75283.
Feb 15, 2019 17:05:01.715 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F75283%2Fchildren in sync item 21734882
Feb 15, 2019 17:05:01.715 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734882: unable to generate sync set query
Feb 15, 2019 17:05:01.716 [0x7f8b89cd7700] Error — LPE: unknown item 79107.
Feb 15, 2019 17:05:01.716 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F79107%2Fchildren in sync item 21734888
Feb 15, 2019 17:05:01.717 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734888: unable to generate sync set query
Feb 15, 2019 17:05:01.718 [0x7f8b89cd7700] Error — LPE: unknown item 78820.
Feb 15, 2019 17:05:01.718 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F78820%2Fchildren in sync item 21734895
Feb 15, 2019 17:05:01.718 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734895: unable to generate sync set query
Feb 15, 2019 17:05:01.719 [0x7f8b89cd7700] Error — LPE: unknown item 72759.
Feb 15, 2019 17:05:01.719 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72759%2Fchildren in sync item 21734897
Feb 15, 2019 17:05:01.719 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734897: unable to generate sync set query
Feb 15, 2019 17:05:01.720 [0x7f8b89cd7700] Error — LPE: unknown item 72747.
Feb 15, 2019 17:05:01.721 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72747%2Fchildren in sync item 21734898
Feb 15, 2019 17:05:01.721 [0x7f8b89cd7700] Error — Sync: skipping items for sync list 13113028, sync item 21734898: unable to generate sync set query
Feb 15, 2019 17:05:01.811 [0x7f8b89cd7700] Error — LPE: unknown item 65264.
Feb 15, 2019 17:05:01.811 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F65264%2Fchildren in sync item 21734878
Feb 15, 2019 17:05:01.812 [0x7f8b89cd7700] Error — LPE: unknown item 75283.
Feb 15, 2019 17:05:01.812 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F75283%2Fchildren in sync item 21734882
Feb 15, 2019 17:05:01.814 [0x7f8b89cd7700] Error — LPE: unknown item 79107.
Feb 15, 2019 17:05:01.814 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F79107%2Fchildren in sync item 21734888
Feb 15, 2019 17:05:01.815 [0x7f8b89cd7700] Error — LPE: unknown item 78820.
Feb 15, 2019 17:05:01.815 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F78820%2Fchildren in sync item 21734895
Feb 15, 2019 17:05:01.816 [0x7f8b89cd7700] Error — LPE: unknown item 72759.
Feb 15, 2019 17:05:01.816 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72759%2Fchildren in sync item 21734897
Feb 15, 2019 17:05:01.818 [0x7f8b89cd7700] Error — LPE: unknown item 72747.
Feb 15, 2019 17:05:01.818 [0x7f8b89cd7700] Error — Sync: failed to generate query for path library://97e60895-34f9-49b1-8bcb-8203c1178c2e/directory/%2Flibrary%2Fmetadata%2F72747%2Fchildren in sync item 21734898
