"Zoom" Display Mode incorrectly behaves like "Stretch" causing Aspect Ratio Distortion
Server Version#: 1.43.0.10231
Player Version#: 10.30.6.4151 (f1455a3f)
I’ve identified a reproducible bug specifically on the Onn 4K Pro where the “Zoom” playback modifier functions incorrectly. Instead of maintaining the aspect ratio and cropping the image to fill the screen (zooming), it applies “Stretch” logic, resulting in severe image distortion. I’m testing this with ultra-wide content (letterboxed) on a 16:9 display.
The Functional Difference (Expected vs. Actual): To avoid confusion regarding terminology, here is the breakdown of the issue based on geometry:
  • How “Zoom” SHOULD work: Imagine a perfect circle on the screen with black bars on the top and bottom. If you Zoom, the circle simply gets larger until the black bars are gone. The circle remains a perfect circle, but the left and right edges of the video are cropped out of view, the geometry is preserved.
  • How “Stretch” works (The Bug): If you take that same circle and Stretch it, you are physically pulling the image vertically to hit the top and bottom edges of the TV. The circle becomes a tall oval. Characters look tall and thin, and the geometry is ruined.
The Error: On the Onn 4K Pro, selecting “Zoom” performs the “Stretch” action described above. There is currently zero functional difference between the Zoom and Stretch settings on this device; both distort the image.
Reproducible Example: This behavior is infinitely reproducible on the new series “Pluribus” (2025)
Sample File Details:
  • Profile: Dolby Vision
  • Resolution: 4K (Ultra HD)
  • Aspect Ratio: 2.39:1 (approx) - This is the key, it has black bars that I’m trying to Zoom to get rid of.
Cross-Device Verification: I have verified this behavior across multiple files and compared it against several other clients to rule out file-specific issues. The issue is isolated to the Onn 4K Pro.
  • Fire TV 4K Max: Zoom works correctly (crops sides, preserves geometry).
  • Samsung Fold 5: Zoom works correctly.
  • Windows Plex App: Zoom works correctly.
  • Onn 4K Pro: Zoom fails (Stretches/Distorts).
I’m creating a new thread because while I have found several older threads describing this exact behavior on Android TV devices, they have almost all been archived without acknowledgement or resolution. Given that this issue persists on one of the newest available hardware streaming boxes and affects high-profile content like 2160p Dolby Vision releases, I’m hoping to get this logged as a confirmed bug to help make it easier for the developers to find and squash this bug.
I’ve attached the Plex Media Server logs covering the reproduction of this issue, as well as the XML media info for the file in question. (See attached zip file)
Plex Media Server Logs_2025-11-26_16-09-39.zip (4.3 MB)
Pluribus.S01E05.txt (17.6 KB)
This problem has existed for a long time, and hopefully it can be fixed as soon as possible.
I’m hoping it gets fixed too
This is still an issue, usually with appleTV content. Is anyone at plex able to look into this please?
