'There was a problem playing this item'
fenster214fenster214 Posts: 3Members ✭✭
Not a question - more a solution.
I had this error displaying to me when attempting to play a few items from my library. The files I knew were OK as VLC playback via sshfs direct from the server was fine.
Read a few things about SSL connections, Subtitles, this, that and the other - but none were the cause of my issue.
Turns out it was disk space.
From 'Plex Media Server.log'
Feb 09, 2016 10:55:41 [0x7fc28a3f9700] WARN - Low disk space: 5043020343 bytes source file, 18746441728 bytes capacity, 3664343040 bytes available on /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions
Feb 09, 2016 10:55:41 [0x7fc28a3f9700] WARN - TranscodeSession: inadequate disk space for transcode
Feb 09, 2016 10:55:41 [0x7fc28a3f9700] ERROR - Failed to start session successfully.
Who'd have thought only having 3.5GB~ free would be an issue!
Just thought I'd share.
Comments
  • jamesmacwhitejamesmacwhite Posts: 75Members, Plex Pass Plex Pass
    edited February 2016
    A general rule for transcoding is that you must have equal disk space available relative to the size of the media file being played with an additional overhead for the transcode job. This behaviour was changed recently and is catching some users out.
    In this case you are trying to play a 5 GB video file with only 3.6 GB available on your / partition, which is where /var/lib/plexmediaserver resides. Because whatever device that initiated the playback requires transcoding, you got this error.
    Generally, I'd recommended tweaking your transcode storage location either to a larger secondary volume or to a network location, providing the network and write speeds are adequate to transcode.
    its worth noting, that the transcode directory is only temporary storage, Plex will clean up the transcoded video content regularly.
    Once you've either increased the disk space on the current transcode directory or redirected it to a new location with more space you'll be able to watch Matt Damon in The Martian without any issues ;)
  • DeathStar77DeathStar77 Posts: 2Members, Plex Pass Plex Pass
    How does one go about redirecting the current transcode directory location?
  • orpington2019orpington2019 Posts: 1Members
    I had this same problem. I didn't know about the disc space issued. Thank you. That fixed it.
    DeathStarr77:
    You can change it by going to the plex app on PC and clicking on the "Settings" icon in the upper right hand corner.
    Then click on the "Server" heading.
    Then scroll down to the section
    "The path where local application data is stored"
    and change that location to a hard drive that has more room than the one currently listed.
    I changed mine from the default of something like "C://user/app/data/" to simply "F://" (don't use the quotation marks if you cut and paste this) to send it to one of my external hard drives that has about 100gb of room on it. I was trying to play a 25gb file and didn't know why it wasn't working. My C:// drive only had 18gb free so changing this fixed the problem.
  • haertighaertig Posts: 438Members ✭✭✭
    I have the issue when playing media via Plex Web using Firefox as the browser. I have plenty of available disk space. And it is not even transcoding in the first place. Additionally, the video plays just fine, I get the message after stopping playback. So it appears to be a somewhat bogus message.
    The fix is to switch to Chrome as the browser. The message disappears. Firefox has been going downhill lately. I am actively trying to learn Chrome and get all my web browsing switched over there. It's a bit of a learning curve finding equivalent plug-ins since I've been using Firefox/Mozilla since the dinosaurs roamed. It's sad to see it degrading recently.
  • adampskiadampski Posts: 19Members, Plex Pass Plex Pass
    Didn't even try clearing cache or trying a new profile? Seems stupid to blame the browser as a whole without even troubleshooting the basics!
    Actually, it seems more stupid to comment negatively based on a false assumption that I did not do any troubleshooting. How would you know any of that? There's a reason why they say, "An assumption is the first step towards a screw-up". I had indeed done very much troubleshooting, cache-clearing, etc. It didn't help. I am running on Linux. And it hasn't helped with my friends who also report a degradation in Firefox on their Linux and Windows computers too. Or for my wife who runs on Windows. I am indeed sad to see Firefox starting the slide downhill. But don't blame me as a user. Many others have noted the same issues I'm seeing creep in. Slowness, hangs/stalls, video playback quality not as good as in the past, etc. Firefox is still usable at this point. I hope they can correct course soon before too many users jump ship.
  • ian78ian78 Posts: 256Members, Plex Pass Plex Pass
    I have the same error “there was a problem playing this item” but I’m using Plex Cloud with my media on google drive unlimited, so I don’t have a space issue. Unless the Plex Cloud server has an issue, what can I check?
  • ChuckPAChuckPA Posts: 19,493Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    @ian78
    Plex Cloud operates in a different environment. As such,
    1. Please recreate the problem
    2. Go to Settings - Server - Help - Download Logs and keep the ZIP file
    3. Hover over the media and click Get Info -> View XML
    4. Open a fresh thread in Plex Cloud forum describing the issue again and attaching the ZIP file and the XML.
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support forums: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility List
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
