Hi, i’ve been using the 0.2.2 version with no issues with only 2 sections (Movies and Tvshows) but i rearranged my library to have sections for types of Movies. Eg action, drama, horror and so on. But now RasPlex Will crash or freeze after a few minutes.
512mb pi, rasplex 0.2.2, on wifi.
if i start playing some HD material and then stop to go play something else in HD i only get sound and no picture, but if i play something SD then i get picture. after some minutes it freezes up.
in the logs you will se HD material working, then HD material only playing audio, the SD material working and again Hd material with only audio.
B)
Hi, i've been using the 0.2.2 version with no issues with only 2 sections (Movies and Tvshows) but i rearranged my library to have sections for types of Movies. Eg action, drama, horror and so on. But now RasPlex Will crash or freeze after a few minutes.
This happened to me from version 1.3.6 and up! I reported it then but have gotten no response. You are not alone. If you want a working Rasplex the only version that works for me is 1.3.5.
Something changed after 1.3.5 but no one seems to know what exactly. From 1.3.6 on they just added more features not caring there were issues with the code. I have tried every version since then and they all crash my Pi. Re installing 1.3.5 always works B)
