0.9.14.0 Problem with xbox 360??
Anyone experiencing any issues with the latest version?
Server is running on ubuntu server 15.04
What sort of issues are you experiencing? Does it work on other players fine?
Hi BigWheel
Sorry, yes I didn’t explain the issue doh, plex interface on 360 works fine but when you go to play something nothing happens, worked fine before update and it works fine in web browser, home theatre on mac, xboxone and iOS app, just won’t play on the 360 app. Weird right.
I’m also having an issue streaming to Xbox 360s since updating to 0.9.14.0, with the same exact behavior described by Funkie. Every other device works fine. This is running on FreeBSD.
I tweeted out to @plex earlier after coming across this issue. They replied that it’s a known issue and is being currently worked on.
DItto - same error running 0.9.14 on FreeNAS and my XBox 360 as the player. Works fine everywhere else… then of course this is a huge server update but the XBox 360 app was last updated in August.
Perhaps an updated client should/will be released?
Ok thanks guys I’ll leave it in your very capable hands
0.9.41.1 solved my problem with viewing on XBox 360. Initially, I kept getting the “cannot connect to server, please retry” for several minutes, but it worked after a reboot.
Thanks for the quick turn around
Still an issue for me. Connects to server fine and shows content but when I attempt to play anything a spinning wheel appears for a few seconds but nothing plays.
Installed 0.9.41.1, restarted server and issue is now resolved, gotta say guys I knew it was in capable hands but what a turn around very impressive.
Great work and thank you, much appreciated.
i’m still having the same issue, any ideas?
