[topic moved from thread about 1.18.6 on windows - mod]
+1 1.18.7.2415 (PlessPass) does not work on MacOS… server is unreachable until I force quit Plex activities and start up again. Then crashes again in few hours and is unreachable… horrible update!
Very frustrating since everyone I referred to Plex is asking me why and I have no idea myself?! These last few updates remind me of the unstable 2010/2011 Plex server, someone really screwed up…
Anyone who is having issues with the latest beta releases, rollback to the latest stable public release and it works as it should. Latest beta is pure garbage for stability…
Just wanted to add that if you’re having issues getting logs the usual way, because the server is not responding, there’s other easy ways to do it on macOS.
Use the Console App select the PMS log (From Log Reports on the sidebar) then left click and Reveal in Finder this should lead you to the dir all PMS logs are.
Navigate directly to the default path to logs: ~/Library/Logs/Plex Media Server
@odoylerules can you please upload you’re logs to? Or look in the other thread to check if you’re issue is related (hint: if you use iTunes its likely it is)?
Although never used, the iTunes plugin was enabled on my server. I have disabled it and will update to the latest beta again and report back if it happens again…
Interesting find as I do not use the iTunes plugin and 1.18.7.2438 has not faulted. I wonder as iTunes is no longer with Apple Music, Tv, Podcasts are replacements as of Catalina.
Yes it is the same issue following an error when loading iTunes media
Feb 22, 2020 12:30:27.488 [0x7000013ef000] INFO - iTunes: parsed library in 2.5 seconds.
Feb 22, 2020 12:30:27.488 [0x7000013ef000] DEBUG - Loading com.plexapp.plugins.itunes is complete (success=1)
Feb 22, 2020 12:30:27.491 [0x7000013ef000] ERROR - Couldn't rename file "/Users/corlin/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.itunes-new.db-shm" to "/Users/corlin/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.itunes.db-shm": No such file or directory
Feb 22, 2020 12:30:27.491 [0x7000013ef000] ERROR - Couldn't rename file "/Users/corlin/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.itunes-new.db-wal" to "/Users/corlin/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.itunes.db-wal": No such file or directory
Feb 22, 2020 12:30:27.497 [0x7000013ef000] DEBUG - iTunes: There are 19176 audio tracks and 38 video tracks.
Feb 22
I do use iTunes just not in Plex. Yes, that setting was enabled, so I disabled it and it worked. Years ago I added the iTunes Channel to my PMS. I thought I removed it a long time ago, guess not. I have a iTunes Match Subscription so although my iTunes library shows music available, the files are not stored locally. I’m on MacOS 10.13.6 so the new Apple Music app does not apply. The true test will be if PMS works tomorrow, so far so good on 1.18.7.2438. Thanks for keeping on it!
This started happening to my Plex Server today, version 1.18.7.2438 running on Mac OS 10.14.6. I have disabled the iTunes plugin (FWIW, that feature has never worked, always times out, I assumed it was because my iTunes library is close to 400GB) and so far so good. Crossing fingers that it remains up. Thanks everyone
