1.19.3.2740-add6f438d on UBUNTU 14.04 LTS keeps crashing at startup
Server Version#:
Player Version#:plex-dump-files.zip (113.6 KB)
Recently a catestrophic filesystem failure forced me to reinstall the OS on my system (currently UBUNTU 14.04 LTS). Thankfully, all the data outside of /boot is still accessible. So I installed the OS on a newly-added drive, and mounted the old system under /oldboot. So everthing that was in the root filesystem (/) before is under /oldboot. Plex, for example, is under /oldboot/var/lib/plexmediaserver and its children.
Now I have installed PMS on the server. The new drive isn’t big enough to contain the 47GB plex content, so after installation I did:
> service plexmediaserver stop
> mv /var/lib/plexmediaserver /var/lib/plexmediaserver-save
> ln -fs /oldboot/var/lib/plexmediaserver /var/lib/plexmediaserver
> service plexmediaserver start
but the service won’t start. I have included dump logs that I hope will help us know what the issue is. What should my next step be? I found information that tells me where these logs are, but no information about what to do with them.
I’d appreciate your help.
The DMP files don’t help at this point.
First, can you provide some more info?
  1. SYSV init or Systemd ? Looks like you’re using SYSV-init ?
  2. grep plex /etc/passwd and get it’s UID/GID
  3. Now check the owner of the new temporary location. If the current Plex UID/GID doesn’t have ownership, it won’t go very far at all and will crash.
  4. Also, may I have a tar.gz or ZIP of the Logs directory underneath Plex Media Server ? This will tell me if your database is intact.
Thanks for your reply @ChuckPa! Ubuntu is an upstart system.
plex-logs-dir.zip (24.0 MB)
Before the rename steps that put the old plexmediaserver folder in place of the new one, I did:
find /var/lib/plex* -uid old-plex-id -exec chown plex {} ;
find /var/lib/plex* -gid old-plex-gid -exec chgrp plex {} ;
So now everyting there is owned by the new UID/GID of plex - or by root, as before. But I’ve attached a listing: full-plex-file-listing.zip (6.1 MB)
I don’t know what “the new temporary location” is but it’s probably in that listing I uploaded.
Thanks SO MUCH for your prompt attention to my post. Means a lot!
BTW: plex is 999:999 now. Was 122:131
I can save you a lot of pain right now but you won’t like it.
Upstart support ended in 2016 when Ubuntu ended it with the release of 16.04
Upstart was a one-release-only experiment.
At this point, I can only suggest you bit the bullet and take the full step to 16 or higher. I can tell you 20.04 LTS is both stable and quick. I use it now for production.
I recommend backing up (tar ball) that which is important (like the ./Library) from /var/lib/plexmediaserver then rebuild the whole machine from scratch.
Carrying over your system into a new, stable, and fresh installation is a “win” in more ways can you can count (1. no upstart 2. No upgrade on top of other upgrades 3. systemd, 4. current version runtime libraries (14.04 doesn’t work too well anymore)
Thanks, ChuckPa. This is the right time for such a move. I’ll give it a shot. I really appreciate the support.
