2 Hard Drives 1 Library.
I have two external hard drives. One is 8TB the other is 4TB. I created a copy of the 4TB on the 8TB. Can I add both to plex as sources for the same files? What happens if I add somethings to the 8TB that isn’t on the 4TB?
Yes you can…
Just edit the library, add folders, point to the folder on the second drive you want included in the library.
Both Drives content will appear in 1 library.
1/4 thru the transfer. I’ll give it a try.
Thanks!
You can easily indicate multiple folders for one library.
