2 minor Android TV Client gripes
  1. When moving through items on the discover tab, when the trailer auto starts in the background a half second of audio blares through the speakers. If the volume is up that makes for a jarring sound.
  2. For the small group of us loyal preroll enthusiasts, if you start a movie expecting a preroll to come up first sometimes the movie will play for a good 5 seconds or more and then suddenly stop and load the preroll. Then go back to the beginning of the movie again when done. Again not a great or smooth experience.
FYI the Roku player handles both of these situations perfectly.
  1. When you are on Trending?
  2. I could not reproduce this. Which device are you using and what version is the Plex app on it.
  1. Yes on the trending trailers section.
  2. On Nvidia Shield Pro beta Android app 10.5.0.4973
i’ve been able to reproduce #1 but can’t reproduce #2. not sure if if it because I don’t have that particular model Shield but will keep trying. Is it possible to get your android tv logs after #2 happens.
