It seems that the media keys are not working, being able to use play/pause is personally very crucial in my media consumption.
Same issue here. I don’t seem to be able to control Plex from the play/pause/next/prev global hotkeys anymore, and the Windows dialog that shows up when I attempt to use them shows nothing playing, just ‘Plex’. Picture
On Win 10 Pro Insider Preview build 14352
Can anyone try on 10.0.10586, to see if this is an Insider Preview bug?
I am running 10586.318
It’s strange because media keys work fine with my Logitech keyboard but not on my Surface Pro 3 keyboard. Will need to take a better look at this.
Just tested my non pro Surface 3 keyboard and the media keys don’t work either. They work in the non beta app without issues.
Sitting on a Logitech G510 and its not working, same result when i restarted Logitech Gaming Software.
I’m using an MK700, but shouldn’t make any difference :-/
This problem still exist, any words on an update?
A ticket has been created internally so we can prioritize the fix for this issue. Thank you for your patience!
I’m not sure if this should be posted here, but a similar problem exists with Windows MC remote control. During video playback, the back arrow doesn’t exit a video and take me back to previous screen; stop, fast forward, reverse, pause, chapter backward, and chapter forward do not function as in the standard PHT.
Updated windows to the anniversary update (1607)
When i press the play/pause key i now get the pop up window (se image) but it does not pause or play the movie if plex is not the application in focus. If i select plex then it works.
This was fixed a few versions back, FWIW.
