3 dot menu hangs for 15 seconds
installed on synology 1520+
When i go to check the 3 dots menu (long menu with “get info” at the bottom, opposite from pencil icon), i get a swirling circle for 15-20 seconds. Eventually the menu will open, but it seems like forever. it never use to do that in the past and it started a few days ago i think.
Since this started, i have cleaned my pc temp files, updated the plex server, and restartd the DS 1520+
Plex is having an issue at the moment and it seems its also affecting the UI…
It probably looks like this =>
Edit##
seems to be working again
