3 live tv bugs that are still current
3 bugs with live tv on Android TV (Shield) 10.26.0.2578
  1. in DVR Schedule, there is no highlighting of selected object as you try to scroll up and down on scheduled items to change settings.
  2. when you select “record” from TV guide, the “Advanced” section is missing under certain circumstances.
  3. when live tv stream has multiple audio streams, the stream starts with the default language but shows as ENG (which is not always the default language). Only way to switch is to toggle to the other language and back again.
example
stream has ENG and FRE - default stream is FRE. Stream starts with French but ENG is ticked in the UI. To switch to english you have to select french and back to english.
