429 error on fresh install
Server Version#: 1.42.2.10156
Player Version#: n/a
Hi, I’m in the process of putting together a new Plex server and apparently it’s hit a rate limit for grabbing the SSL cert? I disabled wan access for Plex for just over 12 hours, but still received the same error again when reconnected. Do I need to wait longer or is something else going on? Thankyou!
Oct 24, 2025 10:29:05.431 [137499888728888] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> <errors> <error code="1003" message="API rate limit exceeded" status="429"/> </errors>
@camx
I looked at Plex.tv.
Your server’s certificate got stuck in generation.
You were getting the 429 for the CSR because another was already processing.
I cleared the existing. It has now created a new one.
Please restart the server.
Hey, ChuckPa! Is there any way you could reset my cert also? I am having the same exact issue as shown in the console log above.
Cleared. Please wait 10 minutes, then stop and restart Plex server.
Thank you for the quick response! Solved my cert issue. I truly appreciate your help. Especially on a weekend! Thanks again and have a great day.
