Having an issue when playing almost all 4K movies through either plex player or plex app on Samsung 4k TV. The sometimes play for a few seconds before buffering other times they just lock up the player. If I watch the same movies using VLC they work fine. These are playing over the LAN and not remotely.
Spec is
Intel i7 4770 @3.4ghz
32Gb RAM
Raid SSD
GTX 1070Ti 8gb
Gigabit lan connected to Buffalo 16Tb NAS
No need to be a smart ass bell end about it, I did look for an answer but maybe as Iâm quite new to plex I wasnât asking the right question. So basically the plex player is a bit â â â â as it plays fine with vlc. Itâs not transcoding either and like I say some 4k work fine.
Not remotely no, itâs over a gigabit lan itâs struggling. I knew it wouldnât play 4k over the wan as my internet upload isnât fast enough.
Iâve tried it on the built in plex player on the Samsung tv and also on a firestick.
It just seemed odd to buffer on a lan connection when it plays fine on vlc over the same lan. Even if I play it directly on the plex server through plex it buffers.
