I’m having an issue when playing 4k videos on the Tizen app.
I have a 4k video downloaded from Youtube and sitting on my Plex server running on a Macbook running Ubuntu 16 with 8 cores (i7-4980HQ CPU @ 2.80GHz) and 16 gigs of RAM. This server is dedicated for plex and storage is a Synology drive mounted over nfs.
When I play this video on the Plex app on Apple TV, and on the Plex Web App in Firefox, it plays nicely, without issues neither any buffering. On htop I don’t see any transcoding happening, so it’s direct playing.
When I play it on the native Plex Tizen app on my Samsung (QN65Q80RAFXZA Flat 65-Inch QLED 4K Q80 Series Ultra HD Smart TV with HDR) over wifi (Mesh Google Wifi with three wifi points) I experience constant buffering, like every 5 seconds. I see a transcoding process running when it starts:
/usr/lib/plexmediaserver/Plex Transcoder -codec:0 vp9 -hwaccel:0 nvdec -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 cuda -hwaccel_device:0 cuda -codec:1 opus -ss 71 -analyzeduration 20000000 -probesize 20000000 -i /mnt/4kvideo.webm -filter_complex [0:0]hwupload[0];[0]scale_cuda=w=3840:h=2160:format=nv12[1] -filter_complex [0:1] aresample=async=1:ocl='stereo':rematrix_maxval=0.000000dB:osr=48000[2] -map [1] -metadata:s:0 language=eng -codec:0 h264_nvenc -b:0 45000k -maxrate:0 60000k -bufsize:0 120000k -forced-idr:0 1 -r:0 25 -force_key_frames:0 expr:gte(t,71+n_forced*1) -map [2] -metadata:s:1 language=eng -codec:1 aac -b:1 258k -f dash -seg_duration 1 -init_seg_name init-stream$RepresentationID$.m4s -media_seg_name chunk-stream$RepresentationID$-$Number%05d$.m4s -window_size 5 -delete_removed false -skip_to_segment 72 -time_delta 0.0625 -manifest_name http://127.0.0.1:32400/video/:/transcode/session/7s0oawoyctc062obw95mw4fm/984a4472-7f86-489e-816e-5ae585b1128e/manifest?X-Plex-Http-Pipeline=infinite -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -init_hw_device cuda=cuda: -filter_hw_device cuda -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/7s0oawoyctc062obw95mw4fm/984a4472-7f86-489e-816e-5ae585b1128e/progress
When I play this same video from Youtube, on this same TV, I don’t experience any buffering and it plays smoothly. When I turn the stats for nerds I see the connection speed is 35 Mb/s.
So I think wifi issues are ruled out here, and it seems that Plex for Tizen is not able to direct play 4k movies and requires the transcoding which is also not efficient enough (I see all 8 cores spinning).
This is definitely sad. Not being able to experience 4k movies on my local network because of software issues is definitely a bummer, and this issue should be revisited and prioritized.
