4K Windowed Playback Issue on macOS
Setup:
  • Mac Mini 2018 - macOS 10.15.5 (set to “default for display”, ie scaled “retina” 1080p display output)
  • LG C7 4K connected via HDMI through Denon AVR-X2200w (HDMI passthrough, no filtering of HDMI signal etc.)
Issue:
  • When Plex Media player is first launched and a video is played it will always display in a smaller window (see attached screenshot)
  • If you go back to the menu and play the same file again it will play normally in full screen
  • Any file played after this works normally in full screen (until the display is turned off or Plex Media Player is relaunched)
  • If display output is set to native 4K the issue still happens but much more randomly (I cannot easily reproduce as per above)
  • I have also tested with the new 3.0.0.32 Plex Media Player which appears to fix the issue however playback in general is much worse (dropped frames are very high for example)
Server Version#: 4.30.2 (latest stable release)
Player Version#: 2.58 (latest stable release)
Tested in 4K output mode and issue still happens every time display is turned off.
