5.1 Audio out of 7.1 HDMI is different for Dolby vs DTS
Audio and the surrounds has been a mess on XBOX One I know but some of it seems to be fixed. The XBOX is set to output 7.1 through HDMI. Playing Netflix 5.1 material works as it should, playing Dolby 5.1 in Plex does too but playing DTS 5.1 puts the surrounds out of the rear. Is the MS or Plex…surely one of them could swap them to be correct ?
It sounds like it could be a problem on the Plex server end. DTS is currently not supported on the Xbox one so any DTS stream will need to be reencoded and it sounds like the channel location could be getting mixed up/dropped
Hopefully the Win10 Universal App will fix this when it comes to XBOX
@reded23 said:
Hopefully the Win10 Universal App will fix this when IF comes to XBOX
fixed that for you.
and it won’t fix the issue because the UWP as a platform doesn’t have a DTS decoder so it won’t ever happen unless MS decide to be kind and let Plex use the api’s they will use for the upcoming bluray bitstream support.
