7.24 beta: handleStreamRead code 335544539: short read
having problems with the new 7.24 beta that I tried out today on the new Shield 2019. Playing UHD files (normal and DV) produces the following error on the server:
Nov 10, 2019 18:26:54.992 [0x7f3459b28700] DEBUG - Request: [192.168.0.23:56206 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (8 live) TLS GZIP Signed-in Token (###)
Nov 10, 2019 18:26:55.672 [0x7f345b5d5700] DEBUG - Failed to stream media, client probably disconnected after 762413056 bytes: 104 - Connection reset by peer
Nov 10, 2019 18:26:55.672 [0x7f345b5d5700] DEBUG - Completed: [192.168.0.17:60136] 200 GET /library/parts/23116/1562799864/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (8 live) TLS 65376ms 762413056 bytes (range: bytes=6878-)
Nov 10, 2019 18:26:55.676 [0x7f345b5d5700] DEBUG - handleStreamRead code 335544539: short read
Nov 10, 2019 18:26:55.676 [0x7f345b5d5700] DEBUG - NotificationStream: Removing because of error
Nov 10, 2019 18:26:55.677 [0x7f345b5d5700] DEBUG - handleStreamRead code 335544539: short read
Nov 10, 2019 18:26:55.677 [0x7f345b5d5700] DEBUG - NotificationStream: Removing because of error
Nov 10, 2019 18:26:56.550 [0x7f341288f700] DEBUG - BPQ: onConsiderProcessing: Idle (true)
Nov 10, 2019 18:26:56.553 [0x7f341288f700] DEBUG - BPQ: [Idle] -> [Processing]
Nov 10, 2019 18:26:56.581 [0x7f341288f700] DEBUG - BPQ: generating queue items from 0 generator(s)
Nov 10, 2019 18:26:56.583 [0x7f341288f700] DEBUG - BPQ: generated 0 item(s) for queue
Nov 10, 2019 18:26:56.586 [0x7f341288f700] DEBUG - PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Nov 10, 2019 18:26:56.587 [0x7f341288f700] DEBUG - BPQ: [Processing] -> [Idle]
some files start and then sometimes stutter and then the player restarts, while the other movies will simply restart the player without even playing. non dolby vision files that worked before no don’t. I’m on Sony X930E and have not applied the new Shield 2019 hotfix. ideas?
Are you on the SHIELD Tube or Pro? Would you be able to provide the client logs as the server logs don’t really tell us much. Information about grabbing the logs is available here; https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
I have the tube.
custom made from star wars UHD blu-ray, converted with DVDFab into a single layer Dolby Vision file. this stands out:
MediaCodec found (OMX.Nvidia.DOVI.decode) for video/dolby-vision
[FF] Stream ignored as codec type is unknown.
[FF] Video decoder doesn’t support dolbyvision (video/dolby-vision).
am I somehow converting it wrong?
Star Wars Single-Layer DV no sound.log (65.0 KB)
from normal HDR UHD bluray, crashes after a couple of seconds:
The Matrix.log (189.9 KB)
file found somewhere on this forum, crashes after a couple of seconds: LG Earth Dolby Vision UHD 4K Demo.ts.log (77.5 KB)
I’m having big problems, help?
