8.30.0.30780-beta Android TV playing next episode before countdown done
Got 8.30.0.30780-beta on Android TV. Watched 3 episodes of a show. The up next window came up at the end with the countdown but the next episode started playing in the background immediately while the countdown finished. After the countdown the episode came on already in progress.
Does this mean after watching 3 episodes it happened into the 4th, or did it happen between each?
I haven’t been able to duplicate it today so not sure what’s up. I’ll update if I see it again.
I have the same behavior without countdown enabled.
The next one start in background (only audio) every time
If I restart plex client it’s OK the first time but later it comes back (perhaps when I switch off Shield)
