9.9.16 wifi issues
I've tried with 3 different dongles but none of them is working with 9.9.16 (and all of them worked perfectly with 0.3.x  versions).
is it a common issue or something went wrong in my raspberry?
Same here. I tried two different dongles (both D-Link), wich work perfectly with 0.3.1. With 0.9.9.15 and 0.9.9.16 I have two issues regarding wifi:
  1. RasPlex loses connection after a few minutes.
  2. When Rasplex is started, no other devices can use my wifi, as if the RasPlex is acting as a jamming device.
As I said, I tried two different dongles (both D-Link), and I also tried two different wifi stations (AVM FritzBox and ASUS RT-N16.
