A few qustins after maked it running
terminal must be open and after this command ? cause when closing it i can't get their
IN HEBREW subtitles things like . , ! ? are in the beginning of the line and not the end-what to do ?
Yes, terminal must be open. At this early Alpha stage Plexconnect is designed to shutdown when you close Terminal. Keep it open for now if you want to use it.
What about the hebrew subtitles ?
Closed because you are asking the same questions in multiple threads.
