PlexConnect Remain Running
Hi All,
New to PlexConnect. I just recently upgraded my ATV2 to the newest ATV3 (mostly because of the PlexConnect project). I was able to get everything re-routed and working, a few movies I tried played fine, but I noticed when I closed out of Terminal and later went to the Trailers app... it was searching for Trailers and ultimately failed because the DNS had changed. Just curious, do you need to leave Terminal open at all times with the PlexConnect script running or am I doing something wrong? I was just hoping there was a more permanent solution than to open up Terminal, type in the code to make it run and leave it open the whole time. Please keep in mind I am a newbie and just started messing around with this stuff, so any advice or help would be appreciated. Thanks!
There are several guides around here on how to set it up terminal-less - as a daemon. Feel welcome and keep on searching!
It is not in the main code yet, mostly for compatibility issues with different OSs and my lack of understanding... :-D
http://forums.plexap...ect-at-startup/
