if a .srt file is in a folder with a movie, you have the option to see subtitles or not…
similarly could there be an option to have another text file (maybe *.rdn for redaction) which would allow you to skip parts of a movie for parental controls? For example many movies are mostly fine for my kids to watch, but i may want to automatically skip parts. srt files have timestamps for text to show on the page, but this new rdaction file could have timestamps for sections to skip (or silence for language).
it would be enabled same as subtitles… option to enable redaction, pick your redaction file if detected, or none to disable redactions and play full movie.
i thought i could write something like this as a plugin, but sadly you guys are removing that ability.
for example redaction file can be structured like this (note that it can be parsed essentially the same as a .srt file… after all, an .srt file would usually be the starting point since you can easily find all the bad words via .srt):
A numeric counter indicating the index of the redaction.
Start and end time of the redaction separated by –> characters
First word is redaction type (Skip or Mute), rest can be ignored as comment
A blank line indicating the end of the redaction section.
move-name.rdn
1
00:05:00,400 --> 00:05:15,300
Skip this due to excessive violence
2
00:05:16,400 --> 00:05:25,300
Mute
There’s already an existing feature suggestion discussing such an option (so far with Förster limited interest from the community). I recommend you comment/vote in that thread in order to avoid distracting/dispersing votes.
There’s a slightly related and more popular suggestion asking for a profanity filter (based on subtitles as well as input from online sources too).
Unless I’m missing some unique aspect of your suggestion, I’ll close this thread as a duplicate.
