Ability to Change UI Colors/Theme
I really think it would be nice if you can change the Color of the Web-UI or at least the ability to select from a selection of themes to what you want instead of what Plex wants…
And maybe even the ability to have different Colors for Each libarary
Colors you should be able to change
  1. Background
  2. Menu Bar on Side/Top
  3. Item(s) Selected
  4. Number of Unwatched Items
I really don’t like the new UI color for the new release and i’m sure others do.
There’s actually an existing suggestion aiming for an option to allow replacing the focus / highlight color(s) used within the apps. That hasn’t however gained much support/attention since it was raised.
I suggest you comment/vote in that thread in order to avoid distracting/dispersing votes (and attention).
In that case I’ll close this thread as a duplicate.
that suggestion is for just the highlights… this suggestion is for the the UI as a whole
So you’re looking for Plex to allow theming of their web app / other clients?
Something like this?
If the Plex Media Player Desktop is/includes the Web UI then yes.
