Ability to disable channel source
I have 2 HDHomeRun Flex 4K devices. Would like the ability to disable one. This would prevent the Plex Media Server from using a device and default to the other device.
Furthermore, to priorize the devices, which is used first, second, etc, would also be beneficial for future consideration.
Settings → Manage → Live TV & DVR → (Channel Sources, + Add device option)
Include a checkbox that is enable or disable for each listed.
Why don’t you just remove one of your devices from the Plex Live TV configuration?
Yes. Then you need to add it again and scan all the channels. Then build the schedule over, etc.
I realize I’m unique. Most people don’t have two tuners, nor a need to dynamically change which to use.
+1 I would also like to be able to disable a channel source without removing it completely.
