[Implemented] Feature Request: Save Custom Filters
The new filters are great. I would like a way to save frequently used custom filters into the menu.
+1 must have feature :slight_smile:
@Tanguyb Don’t forget to give my original post a like so it counts. :slight_smile:
I would love to have the ability to pin frequently used filters to the dashboard allowing to quickly go to favorite subsets.
This is something that should have been in there from the start.
You can in the meantime save custom filters as smart playlists. The filter criteria of those lists can also be edited.
To use this, you might need to use the hosted version of Plex Web (the locally bundled version on the latest PMS is still on 4.30.2; this feature requires 4.31.1 or newer).
PS: closing this suggestion and returning your votes so you can push other suggestions :smiley:
