Because I am in the Chinese area, most of the music is from China, Japan and South Korea, so I use lastfm as the music database of plex, but I found that after updating the lastfm information, plex will not display the latest information after refreshing the metadata. For example, I edited Singer profile in lastfm, but the latest metadata cannot be obtained after plex is refreshed, how long will it take for plex to obtain the latest information from lastfm?
Plex will not use metadata from last.fm whatsoever. (Except artist photos and artist bio’s, if they are nowhere else to be found)
i mean this,Or, does plex consider adding Chinese support for music information?
This is the old metadata agent which will be removed from Plex at some time.
It already has received no updates for years.
Do not use it anymore.
In the future, there will be only support for “Plex Music”.
I don’t recommend removing the lastfm proxy, because there are many singers and song information in languages other than English. If you really need to remove it, can you consider that plex’s own proxy supports Chinese and other languages, or open translation channels…
