First of all, I am very sorry, I use the translation software and there may be communication problems.
This is a question about video tracks. One of my episodes, how do I default to using the same audio track for all videos?
The same episode, there are English and Japanese, Japanese is in track 2. But the video default track 1, which causes me to manually select track 2 and play again each time I open the next episode. Is there a way to set it globally? For example, this episode uses Track 2 by default, or does the episode use Japanese by default?
Thank you very much
The only way would be to put in a preference for Audio = Japanese
into your plex account.
https://support.plex.tv/articles/204985278-account-audio-subtitle-language-settings/
This of course will only work if your files actually have proper language information in them.
Thank you very much! This seems to be the only solution now.
I hope I can add this feature later, set the audio separately in the library or in the episode.
