AC3 files causing issues on Android Boxes
You can try and disable hw decoding in the plex prefrence file for ac3 and/or dts.
Software decoding for ac3 and dts is supported. Downmixing to stereo is not supported but maybe your box can handle it (I had to edit a system file to have it)
/data/data/com.plexapp.android/shared_prefs/com.plexapp.android.xml
needs to be modified
<boolean name=“general.deviceSupportsDTS” value=“ false ”>
<boolean name=" general.deviceSupportsAC3" value=“ false ”>
Unfortunately this requires root. My device is not rooted.
Hey,
I had the same issue. I have a beelink gt1 android box. It was originally running android (not android tv). I couldn’t play AC3 file. To get it to work I had to go to settings, advanced, player, optional audio support and disable AC3.
I recently updated the firmware to use android TV on this box. I installed the plex for android tv app and got the connection lost error when playing AC3 files. Figuring I needed to disable AC3 I went to options, advances, there was no option for optional audio support.
Seeing one of the images above I noticed there was an option next to audio pass through called Optical Encodings. I did not have this option. Or so I thought. I changed my audio pass through to optical and the Optical Encodings setting became visible. I disabled AC3 then changed my pass though back to HDMI and voila I had audio.
It seems that this setting is not for optical encodings specifically and should likely be visible all the time. The name changed from “Optional Audio Support” to “Optical Encodings” between the android app and android tv app.
Hope this helps someone get their audio working
What’s BDigital saying it’s working. I think it’s about transcoding, and the only option to activate transcoding for audio it’s to activate optical passtrough and dezactivate AC3/DD direct stream.
Hoping devs gonna put a general option in the future updates.
Yes I’ts working, I struggled a couple of days with my mecool KM3 Android 9 not playing AC3, until I found BDigital post that solved the issue. Thks a lot!
Isso funcionou para mim também na MECOOL KM3 ATV Google Certified Amlogic S905X2 Android Pie 9.0 OS 4K TV Box with Voice Remote Dual Band WiFi Bluetooth USB 3.0
  • Black 4GB RAM+64GB
Que briga valeu… comprei duas unidades ja esta bem chateado.
Thank you very much for the solution !
Solucionado también en Smart TV Thomson con el mismo problema. :clap: :clap:
Thank you so much¡¡¡
