Accessibility for impaired users
Hello, and thank you for giving users a place to hear them out.
I’m asking to improve the accessibility for impaired users of the android app, if possibile: many buttons don’t have a label and you can’t tell exactly what you are doing. Also, scrolling the library with features such as Google Talkback enabled is clumsy, and if you tap on the Android action buttons on the bottom virtual keyboard (back, home, menu), you’re stuck there, and you have to tap somewhere else since using the accessibility function to move between elements won’t take you anywhere else.
I’d be glad to see changes in such sense.
Thank you very much,
Simone
