Server Version#:1.20.1.3252
Player Version#:plex iphone app and sony tv app
Hello,
my Plex server, running on Qnap says it is Fully Accessible outside your network, but when I try playing movies streaming to my TV 1 Sony TV with built-in PLEX app or to my TV 2 office TV with Google Chromecast the iPhone app says I do not have a direct connection
if i use the TV 1 sony TV with built-in PLEX app, the built-in Plex app also says no direct connection available
on my home wifi network
iphone plex app
TV 1 is sony TV with built-in PLEX app, hard wired to ethernet
TV 2 has google Chromecast connected with home wifi
my qnap Plex server says
Fully accessible outside your network
Manually specified public port 32400
qnap server has static IP 192.168.1.100
I have my UniFi Security Gateway set to allow port forwarding
anywhere / port 32400 / forward ip: 192.168.1.100 / forward port 32400 / protocol TCP
Upnp is enabled
USG is up-do-date
my modem is in BRIDGE MODE
consumer modem does not have a static IP address
Motorola cable modem
I’ve tried
deleting the iPhone app and reinstalling.
restarted the qnap NAS
a. it is also set to restart every night at 3:00 am
power cycled both TV’s
power cycled the google chromecast
deleted the port forwarding rule and recreated the same rule
once in a great while the app and/or the TV will say they are connected to Plex directly, but most of the time they say they do not have a direct Plex connection
See if that helps, I personally use these settings myself. My ISP also doesn’t have static IPs however that being said my IP doesn’t actually change unless I power down the modem and leave it off for quite some time - I’ve had the same IP now for a quite for a while but it does change on me during extended power outages. G’luck
now REMOTE ACCESS will say
for a few minutes or a few seconds and if I click on other settings and come back to
REMOTE ACCESS it will say
Not available outside your network
I’m using MANUALLY SPECIFY PUBLIC PORT 32400
I have that port forwarded on my Router
If I UNcheck Manually specify public port
click retry
not available outside your network
IF I then CHECK manually specify public port
click retry
but a few seconds or minutes later it will change back to
( but if I use my cell phone on cell only, I can still access my plex media, so I am still connecting to my Plex Server from outside of my local network )
