Uninstall your Plex from Package Center ticking the first option “Uninstall only”.
IMPORTANT - Install your downloaded Plex pkg via “MANUAL INSTALL”. While going through this process, you have the ability to claim your server. Enter your claim code that you can get from here: Claim | Plex (At first, I attempted to do the install via the Package center (join beta button). This did not work out for me. I did manage to claim the server but all my settings and libraries were lost. Furthermore, when I updated my Plex using the latest PKG that I downloaded, I lost access to the server again)
Finish installation and launch Plex. You should have access to your full library and settings
I experienced exactly the same. Came here and followed the advice to ‘reclaim server’ which I am relieved to confirm HAS worked/resolved the ‘unreachable’ error message.
Hi, i have the same problem as many on here in that i have lost connection to my PMS. I have followed the password reset instructions in the e-mail, but can now not connect to my PMS which is running on Nvidia Shield TV. I have no option to reclaim my PMS as far as I can tell and not sure what to do. Can anyone help?
@railgun Definitely should also practice using the maximum available password length a service offers and having it complex, ideally using a password generator.
Also, changing all your account passwords on a regular basis (I do once a quarter) limits your exposure to leaks like these.
I did not post any screenshots. You will be prompted during the installation process.
Uninstall Plex Media Server using the “Sign out and unclaim” or the “Uninstall Only” option.
Perform a manual installation in Synology Package Center (do not install the beta version).
Select the “Plex Claim Token” option when re-installing.
Click “Get Plex Claim Token”.
Browser tab will open and display a “claim-xxxxxxx” token string
“COPY” the string
Return to the installer window
PASTE the claim-xxxxx into the small window on the form.
Click NEXT until it starts installing.
Installation will need an extra 15-20 seconds for the installer to communicate with Plex.tv and obtain new credentials for your server. After it receives the credentials, it updates your “Preferences.xml” automatically so the server is again connected to your account.
The installer will confirm success or failure attaching. Success will include your Plex account username in the message
I had the same issue after resetting my password and signing into my plex server. Clicked on the claim button and seems to be fine now. It wasn’t possible for clients to connect to the server before.
