Add HDHomeRun tuner on another network
Server Version#: 1.25.2.5319
By adding firewall holes, is it possible to add an HDHomeRun tuner on another network?
Thanks,
Paul
As far as I know, HDHR systems won’t stream across different networks.
Yes, with appropriate firewall rules, you can use an HDHomeRun on a different network from the Plex Media Server. It will likely not be automatically detected, so you’ll have to manually enter its IP address during DVR setup:
That option isn’t immediately available for selection; you’ll need to wait 5-10 seconds before you can click that link and manually enter the IP address.
