Please add the option to re-encode after the DVR processing scripts to encode in software to AV1, and ideally make this a distinct per show/movie option under advanced for archived shows/movies, vs for daily news that I don’t want it done with.
Pretty sure I mentioned software. I would imagine it would be a rather trivial to add options as to what format a user wants for output to be added to expand this to other formats including sound codecs.
I have some HD Homerun Extends, and the hardware encodings look like junk. There are options for other tuners to manually define a transcode. I wanted to do it in software, and later hardware support would be able to be added easy enough.
Software encoding of AV1 is not a CPU-trivial task.
As for HW encoding from a Silicon Dust tuner isn’t the tuner’s fault.
Have you examined the crap bitrates being streamed by the providers these days?
( 3-4 Mbps 1080p )
I had a silicon dust HDHR3. With 20+ Mbps video inbound , the image was perfect
Yeah, the bitrate is very bad and most still only broadcast 720 here, sadly. I have been advertising my HD Homeruns for sale to change for a model thats not the Extend so I can have options for a transcode thats sane. Even the highest profile transcode setting is very bad on the device, I have it disabled. Most of the stuff I archive is 480p, anyway, but I would have liked them to be even smaller hence the request for AV1 (NOT VC1, sorry.)
