Add TIDAL playlists directly to your library
The TIDAL integration has gotten much nicer with Augmented Library and Universal Playlists.
However, I would like to expand my existing TIDAL playlists with the music I have stored on Plex and the only way to do that at the moment is to manually add each song to the library playlist (which, for a long playlist, is NOT fun).
It would be nice to have a one-click solution to add a TIDAL playlist to your PLEX library, as you can already do with Artists and Albums. Just a simple copy will suffice (no need to actively sync for any first version of this functionality).
I’m trying to do the same thing. Is there a solution to this?
tidal implementation, just like any other online source from within plex is simply a half-baked joke
Agreed - adding TIDAL content to a Plex library is extremely tedious - if you could just add playlists this would be solved. That or adding your track lists, etc.
How much harder is it to loop through a playlist and do ‘add to library x’ on Plex’s side really? Just simple programming.
Reviving this, make it happen.
this would be a nice feature to have.
