Adding a podcast url not working
I’ve tried to add some podcast several at several different times trying to see if maybe something was off with either site, but since podcasts launched a little while back and today, I have had no luck. The primary problem seems to be coming from adding a podcast from http://feeds.feedburner.com/
When trying to add 1 Year Daily Audio Bible I receive the following error:
Something went wrong. Make sure the URL is correct and try again.
Any help getting this in would be great.
On a side note, where would I go to leave general feedback and feature requests specific to podcasts?
I’m having the same issue adding this podcast with either of the following URL’s.
http://podrot.com/RSS/podcast-feed/
from feedburner often need to add .xml at the end. so try http://feeds.feedburner.com/dailyaudiobible.xml
try https://itunes.apple.com/us/podcast/podrot-com-podcast-related-brainrot/id1212023402?mt=2
right here in this features section or in feature requests category ( in either case tag it podcasts)
Thanks, I’ll put something together and post in a bit
Thanks, that worked to get it imported at least…but now the issue is the podcasts don’t match what is listed on that site. I.E. There are podcasts posted to the feed that do not show in plex. As you can see from the example below, there are podcasts for every day…yet in plex it is every few days, and does not should the most recent one till 5 days ago… any thoughts here?
I just noticed this also:
the Image for the podcast listing is pulled down. but the image for each episode is blank.
not sure if its a related issue or not:
https://post.futurimedia.com/kfxn/playlist/rss/3.xml podcast in question:
Hey everyone,
I get the same issue with a podcast I am used to listen to available on itunes / RSS:
Here is the feed’s address: LSD, La série documentaire
It includes the xml extension as provided on the source’s website, and I get the same issue:
I don’t know what to do :frowning:
If anyone have an idea, or Plex’s tech guys a fix to this bug ? :angel:
I also have an issue where this podcast link is https://acsportsshow.podbean.com/feed.xml This works in spotify and Itunes. I add that .xml and it does not work. What can I do to fix that?
That link works for me. The iTunes link works as well. https://itunes.apple.com/us/podcast/ac-sports-show/id1373537980?mt=2
The funny part is that today later on it worked. IDK…
