Hello,
I used to listen to a podcast before I started using Plex. Ihad forgotten about it actually.
I found is again. Yeah! Byut, when I search in the Plex search tool in podcasts, the podcast is:
https://feed.podbean.com/stuartmcnish/feed.xml
When it is added, it just says that the URL is wrong.
I even tried
https://feed.podbean.com/stuartmcnish/feed/index.xml
No go.
The system suggests gettign the OPML rewference. but I am using the link provided by the producer of th epodcast.
Any ideas?
Joseph
Hello
Removing the s on https worked!
Thanks for the tip
Joseph
breedy
4
Similar problem. I am trying to add a podcast using the URL. I have tried it without the “s”, no success. Here is the URL I am attempting to add from: https://www.davisphinneyfoundation.org/resources/parkinsons-podcast/
This address is not a “podcast feed” but a regular website.
You can find the feed links on the bottom of each episode’s webpage.
Try this one for instance: https://itunes.apple.com/us/podcast/the-parkinsons-podcast/id1435180246
breedy
6
Thank you. Now i understand. Your help is appreciated!
system
Closed
7
