Hey,
I’ve added the first 2 seasons of King Of The Hill to my library and I’ve got a load of extra bits to add. I’ve tried calling the folders containing the extra content to ‘scenes’ both in the season 1 and season 2 folders but nothing shows. So tried putting the extras from season 1 in the main folder where season 1 and season 2 are but nothing shows?
I’ve looked up how to do it but nothing seems to be working. What am I missing?
Hope you can help
Server Version#: Latest
Player Version#: 4.116.1
Hey @OttoKerner
Thanks for the link, I had looked at that already, but I double checked it.
Here’s what the folder is currently looking like
The extra content is still not showing.
You have added a plex-web tag to this topic. So I’m assuming you are using the web app to verify the results.
And the web app doesn’t have support for extras at the season and episode levels, yet.
But apart from that, there are also errors in your folder hierarchy:
You cannot use subfolders inside of an extras folder.
After you are adding extras, you need to perform Refresh Metadata at the top show level. A library scan won’t do anything.
Local extras for tv shows are only supported if your library is using the modern agent, not the “Legacy” one.
https://support.plex.tv/articles/migrating-a-tv-library-to-use-the-new-plex-tv-series-agent-scanner/
Perfect, that did it!
I got rid of the subfolders and refreshed metadata. Then went and checked on my TV. All the extras are there.
Thanks for the help.
Cheers
