Adding Locast to Plex using locast2plex software
Greetings! Perhaps someone could point me to a video on how to use Locast on Plex using software - locast2plex? Or a more detailed writing on how to? Locast does not integrate with Plex directly. To get Locast streams into Plex requires another piece of software – locast2plex. This proxies the Locast stream and emulates a hardware TV tuner – just like connecting that physical HDHomeRun box. For reference, I am including three links that may be of help/interest:
The GitHub software page suggests loading the software using Docker or Via Terminal/Command Line… Docker was way over my head although I did successfully load but could never figure it out… Nor did the terminal/command line work… there was another link to use a Windows Service (the third link) which make more sense to use however, could not get it to work but I did figure out how to load the service. A good easy to follow video or more detailed instructions would be awesome.
Thank You,
Steve
Locast2Plex is not a Plex product. You’d probably be better off contacting the creator of Locast2Plex.
I’ve tried however, those guys must be really busy! I can usually find my way around a computer with good detail instructions but this one has me perplexed… Thanks for the contact…
