Hello i have the latest version of plex for windows via My Cloud Extra.
I note that it cant link to a movie with a similar name. How can I link plex to the movie manually
Thank you
If your file organization/names follow Plex naming schema, Plex should automatically identify (match) the file to a movie and pick up the corresponding metadata.
If that’s not the case and the item remains unmatched you can use the Match option from that item’s context menu inside Plex to manually match it using a search term or the default matching.
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
https://support.plex.tv/articles/201018497-fix-match-match/
Hi Tom, sorry for late reply. Thanks forvthe info, it did help
