i added some movies and plex found the metadata right away, and now i just added 2 movies and plex did not find the movie’s meta data, even though i named it properly.
when i right click on the movie and choose match and i manually search for the movie, i get no match found.
ChuckPa
September 10, 2023, 7:59pm
2
Fix your naming.
( Year ) – Only the year is in ()
[1080p] [h265] - Square brackets to hide optional confusing information from the scanner.
Example:
Voyagers (2021) [2160p]/
War on Everyone (2016) [1080p]/
We Are Your Friends (2015) [1080p]/
[chuck@lizum movies.2003]$ ll We\ Are\ Your\ Friends\ \(2015\)\ \[1080p\]/
total 22090712
drwxrwxr-x 2 chuck chuck 60 Jul 19 14:37 ./
drwxr-xr-x 228 chuck chuck 16384 Sep 9 19:21 ../
-rw-rw-r-- 1 chuck chuck 22620867077 Dec 28 2021 We Are Your Friends (2015) [1080p].mkv
[chuck@lizum movies.2004]$
I am trying to force a match when I right click on the movie and choose match, then I type in the movie name and click search, I just get a no match found.
ChuckPa
September 10, 2023, 8:21pm
4
May I see the DEBUG logs ZIP which captures this?
dbirch
September 11, 2023, 12:58am
6
If you edit your library does the folder/directory point to /volume1/data/media/movies ? (Please post a screenshot)
ChuckPa
September 11, 2023, 1:43am
8
Have you ever performed this ?
It fixes the limitation where DSM can’t tell Plex that new media is added (automatic detection)
FAQ 16: Increase the number of folders Plex can monitor
Applicable to all supported versions of DSM.
When the Linux ‘inotify’ table fills up, this will cause when Plex to stop automatically detecting new media you add to the server. It will also manifest when there are transcoder problems with Dolby audio codecs.
Linux has a default table size which is static. We can increase this at will.
On some versions it’s 8192. On newer kernels, the default is 65536 folders.
This is easy to incr…
system
Closed
December 10, 2023, 1:44am
9
