Adding multi-volume recordings under one album
Hi Guy’s,
I recently came across a collection of Mozart’s complete works. They are compiled under one album and separated into volumes. Each volume contains 5-6 CD’s (on average, some volumes are larger).
I have tried various ways to add this collection to my library however, it always ends up as one great unorganised mess. Some volumes are identified as “various artists” those that are found seemed to be randomly ordered.
Has anyone here have experience with a similar issue and what approach did you use to tackle the problem?
Server Version#: 4.34.4
If Plex is not configured to prefer embedded tags, your best bet is to make sure your folder/file structure for the album meticulously meets Plex’s guidelines.
If Plex is configured to prefer embedded tags, the folder file structure is still important, but the following How-to will help you make sure Plex is configured correctly. It’s all important, but there is information regarding multi-disc sets near the bottom:
