Adding Music Libraries
Server Version#:4.126.1
I added a 5000 song library without any problems. The folder is called Music-Rock. Everything is structured and organized properly. However, when I add another folder to my library, I called it Music - Country, they are either comingled with my other library or they are in another Library but they are not structured properly. All the albums have the same name? I’ve done this multiple times but for some reason I can’t get it right?
They will be. Adding folders just add that list of files to your other library. If you wanted to keep the libraries separate, you have to create multiple libraries.
What most do is rely on the tagging or the media matching to determine the genre of the song, which will be a lot more than just your normal rock, country, blues, rap. Filter by genre is your friend. Also, that information lends itself really great to the PlexAmp app.
Got it. Thank you.
