Server Version#: Windows
Hi
I want to add hitchhikers guide to the galaxy (TV show). It has no seasons just episodes. Do I still need to use, say, ‘season 01’ folder, or can I just add the episodes straight into the show folder?
Apologies if this has been answered before, most of the search results are for TV shows withseasons
Yes, you do exactly that. You will organize like any other series.
I assume this is the series Hitchhiker’s Guide to the Galaxy (TheTVDb)
Just name it according to the series.
FYI: In the Plex world, all TV series have season folders regardless.
From https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/#toc-2
Miniseries
A miniseries is really handled just like a season-based show, you simply always use “Season 01” as the season.
Side note: You can configure that show to (edit > advanced) or the entire library not to display seasons within Plex if there’s only 1 season of a show.
For me?
no… just adding to your response
Thanks everyone for the help, its working well and got it sorted. Any specials go in a 00 folder right? I have a making of and a few other specials.
Cheers
